Grandstream GXW-4108 gateway
Discussion in '3CX Phone System - General' started by djrapidjazz, Jan 29, 2007.
  1. djrapidjazz
    Jan 28, 2007
    Hi Guys
    I need a little help from all gurus out there well I have install a 3CX PBX and its working great. So I need to know that can I use grandstream GXW-4108 with a 8FXO to connect to a PSTN lines plz guys tell me because I have order it and in few days I will get it :?
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    hi there
    we've successfully tested the Grandstream GXW-4104 which should basically be the same unit with 4 lines.
    A search in previous posts will show a quick-setup method to setting up the first line for this device.
    You should have no problems ;)
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    311
    The latest manual has a step by step guide how to configure the Grandstream GXW with 3CX Phone System....
