Grandstream GXW4104 can not register to 3CX
Discussion in '3CX Phone System - General' started by zhangjx99, Oct 26, 2010.
  1. zhangjx99
    May 26, 2010
    51
    Hi there,
    I have no problem to add in PSTN gateway 4108, but failed to configure 4104 which I followed same configuration as 4108. any special setting for 4104?
    there is no any message in 3CX log, attached the setting figure.
    Please help. thank you.
    JX
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    If there is nothing in the 3CXLog, try re-checking your GW4104's credentials and Server Address. Also give your PBX a restart. It is possible that your device might of been blocked temporarily since it was spamming your PBX with incorrect registration attempts.
  3. zhangjx99
    May 26, 2010
    51
    Hi LeonidasG, thanks for the advice. I have done so but still the same.
    Best Regards,
    JX
  4. leejor
    11,105
    329
    The 3CX log shows no sign of a registration attempt from the 4104 when the 4104 is powered up? If that is the case then I would double check the server and network settings in the 4104. It may not be "pointed" in the right direction.
  5. zhangjx99
    May 26, 2010
    51
    Hi LeonidasG,
    thanks for the information. problem due to my ignorance on the port setting. I put registration ID instead of port 1,2,3,4, then cased no registration, no log... problem solved.
    Thanks again.
    JX
  6. zhangjx99
    May 26, 2010
    51
    I have just configured Grandstream FXS gateway to be DMZ in remote office, and supperised it is working fine...
    consider as case close, unless someone find a way to use 3cx tunnel or proxy manager... do let me know.
    Thanks.
    JX
