Grandstream GXW4104 line get stuck random
Discussion in '3CX Phone System - General' started by AldoLinares, Jan 12, 2008.
  1. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    I have this serious problem with one client that on random when i get calls from PSTN from the caller is just silence, and then the call just hung up and is not problem of the Gateway because after restart the lines continues to be connected and that i need to restart the server.
    PLease i really need help on this one.
    18:56:11.328 Call::Terminate [CM503008]: Call(14): Call is terminated
    18:55:44.000 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10000 forwards to DN:800
    18:55:44.000 CallCtrl::eek:nLegConnected [CM503007]: Call(15): Device joined: sip:10000@192.168.1.91:5060
    18:55:44.000 MediaServerReporting::SetRemoteParty [MS210003] C:15.1:Answer provided. Connection(transcoding mode):192.168.1.90:7046(7047)
    18:55:43.406 CallCtrl::eek:nLegConnected [CM503007]: Call(15): Device joined: sip:
    18:55:43.406 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(15): Calling: IVR:800@[Dev]
    18:55:43.406 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:800@192.168.1.90:5060]
    18:55:43.406 MediaServerReporting::SetRemoteParty [MS210000] C:15.1:Offer received. RTP connection: 192.168.1.91:5016(5017)
    18:55:43.406 CallLeg::setRemoteSdp Remote SDP is set for legC:15.1
    18:55:43.406 Line::printEndpointInfo [CM505002]: Gateway:[Telnor] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 0001, Ch:3) 1.0.1.2] Transport: [sip:192.168.1.90:5060]
    18:55:43.406 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10000 forwards to DN:800
    18:55:43.375 CallCtrl::eek:nIncomingCall [CM503001]: Call(15): Incoming call from unknown@(Ln.10000@Telnor) to [sip:800@192.168.1.90:5060]
    18:55:43.375 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10000 forwards to DN:800
    18:55:43.359 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:10000@192.168.1.90 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.91:5060;branch=z9hG4bK69c257c797a0af86
    Max-Forwards: 70
    Contact: [sip:10000@192.168.1.91:5060]
    To: [sip:10000@192.168.1.90]
    From: "unknown"[sip:unknown@192.168.1.90];tag=690737346ce3eaf6
    Call-ID: 7fa3c067489498d2@192.168.1.91
    CSeq: 5192 INVITE
    Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, OPTIONS, INFO, SUBSCRIBE, UPDATE, PRACK
    Proxy-Authorization: Digest username="10000",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:10000@192.168.1.90",nonce="12844580142:ff762a6b121083401b355b4e65822b5f",response="8ea95b8de1a5d2e63a087c24c5cd75d6"
    Supported: replaces, timer, path
    User-Agent: Grandstream GXW4104 (HW 0001, Ch:3) 1.0.1.2
    Content-Length: 0
    18:55:36.015 CallLeg::eek:nConfirmed Session 113 of leg C:14.1 is confirmed
    18:55:35.875 CallCtrl::eek:nLegConnected [CM503007]: Call(14): Device joined: sip:10000@192.168.1.91:5060
    18:55:35.875 CallCtrl::eek:nLegConnected [CM503007]: Call(14): Device joined: sip:100@192.168.1.116:5060;transport=udp
    18:55:35.875 MediaServerReporting::SetRemoteParty [MS210007] C:14.1:Answer provided. Connection(by pass mode): 192.168.1.91:5012(5013)
    18:55:35.875 MediaServerReporting::SetRemoteParty [MS210001] C:14.2:Answer received. RTP connection: 192.168.1.91:5012(5013)
    18:55:35.875 CallLeg::setRemoteSdp Remote SDP is set for legC:14.2
    18:55:35.859 Line::printEndpointInfo [CM505002]: Gateway:[Telnor] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 0001, Ch:8) 1.0.1.2] Transport: [sip:192.168.1.90:5060]
    18:55:35.859 CallCtrl::eek:nAnsweredCall [CM503002]: Call(14): Alerting sip:10000@192.168.1.91:5060
    18:55:33.578 MediaServerReporting::SetRemoteParty [MS210006] C:14.2:Offer provided. Connection(by pass mode): 192.168.1.116:5004(5005)
    18:55:33.578 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(14): Calling: PSTNline:10000@[Dev:sip:10000@192.168.1.91:5060, Dev:sip:10001@192.168.1.91:5062]
    18:55:33.546 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:96806654@192.168.1.90]
    18:55:33.546 MediaServerReporting::SetRemoteParty [MS210000] C:14.1:Offer received. RTP connection: 192.168.1.116:5004(5005)
    18:55:33.546 CallLeg::setRemoteSdp Remote SDP is set for legC:14.1
    18:55:33.546 Extension::printEndpointInfo [CM505001]: Ext.100: Device info: Device Identified: [Man: GrandStream;Mod: GXP-2000;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.1.4.18] Transport: [sip:192.168.1.90:5060]
    18:55:33.531 CallCtrl::eek:nIncomingCall [CM503001]: Call(14): Incoming call from Ext.100 to [sip:96806654@192.168.1.90]
    18:55:33.531 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    INVITE sip:96806654@192.168.1.90 SIP/2.0
    Via: SIP/2.0/UDP 192.168.1.116:5060;branch=z9hG4bKfcd3e31b7c9c589c
    Max-Forwards: 70
    Contact: [sip:100@192.168.1.116:5060;transport=udp]
    To: [sip:96806654@192.168.1.90]
    From: "Alma Recepcion"[sip:100@192.168.1.90];tag=dd9550a1a42bfca4
    Call-ID: 890eee6e7cadd0bd@192.168.1.116
    CSeq: 29411 INVITE
    Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, OPTIONS, INFO, SUBSCRIBE, UPDATE, PRACK, MESSAGE
    Proxy-Authorization: Digest username="100",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:96806654@192.168.1.90",nonce="12844580133:a4096883bc63fe9857314d4b511b6866",response="6df54409320ccd0c91542f0b043c6173"
    User-Agent: Grandstream GXP2000 1.1.4.18
    Content-Length: 0
    18:55:31.890 Call::Terminate [CM503008]: Call(13): Call is terminated
    18:55:31.875 Call::Terminate [CM503008]: Call(13): Call is terminated
    18:55:31.859 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10000 forwards to DN:800
    18:55:29.531 Call::Terminate [CM503008]: Call(12): Call is terminated
    18:55:27.078 CallLeg::eek:nConfirmed Session 107 of leg C:13.1 is confirmed
    18:55:27.031 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10000 forwards to DN:800
    18:55:27.031 CallCtrl::eek:nLegConnected [CM503007]: Call(13): Device joined: sip:10000@192.168.1.91:5060
    18:55:27.015 MediaServerReporting::SetRemoteParty [MS210003] C:13.1:Answer provided. Connection(transcoding mode):192.168.1.90:7040(7041)
    18:55:25.265 CallCtrl::eek:nLegConnected [CM503007]: Call(13): Device joined: sip:
    18:55:25.250 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(13): Calling: IVR:800@[Dev]
    18:55:25.250 CallCtrl::eek:nSelectRouteReq [CM503010]: Making route(s) to [sip:800@192.168.1.90:5060]
    18:55:25.250 MediaServerReporting::SetRemoteParty [MS210000] C:13.1:Offer received. RTP connection: 192.168.1.91:5008(5009)
    18:55:25.250 CallLeg::setRemoteSdp Remote SDP is set for legC:13.1
    18:55:25.250 Line::printEndpointInfo [CM505002]: Gateway:[Telnor] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 0001, Ch:1) 1.0.1.2] Transport: [sip:192.168.1.90:5060]
    18:55:25.250 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10000 forwards to DN:800
    18:55:25.218 CallCtrl::eek:nIncomingCall [CM503001]: Call(13): Incoming call from unknown@(Ln.10000@Telnor) to [sip:800@192.168.1.90:5060]
    18:55:25.218 LineCfg::getInboundTarget [CM503011]: Inbound out-of-office hours' rule for LN:10000 forwards to DN:800
    18:55:25.203 CallLeg::eek:nNewCall [CM500002]: Info on incoming INVITE:
    Via: SIP/2.0/UDP 192.168.1.91:5060;branch=z9hG4bK973366b432c79762
    Max-Forwards: 70
    From: "unknown"[sip:unknown@192.168.1.90];tag=fd249483dba42365
    Call-ID: b2c156255ee1b9c4@192.168.1.91
    CSeq: 22693 INVITE
    Proxy-Authorization: Digest username="10000",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:10000@192.168.1.90",nonce="12844580124:21f6e8882e1001d95dda2acdcffb9eba",response="7d1560d4aa52a26dbfcb8022feba34af"
    User-Agent: Grandstream GXW4104 (HW 0001, Ch:1) 1.0.1.2
    Content-Length: 0
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    Aldo,
    Since you are a 3Cx partner, I suggest opening a ticket via our support system. Please include the firmware version of the gateway that you are using as well as the phone
  3. rthee
    Feb 9, 2010
    6
    I am using 3CX Phone System 7.1.7139.0.
    I have the similar problem. When client calling to office at knock-off hours, it will forward the call to our mobile. It remains silent all the time when forwarded call picked up. Here is my server activity log:
    14:42:33.359 [CM503007]: Call(623): Device joined: sip:10000@192.168.70.64:5060
    14:42:33.359 [CM503007]: Call(623): Device joined: sip:10002@192.168.70.64:5064
    14:42:33.359 [CM505002]: Gateway:[Grandstream GXW-4104] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 1.1, Ch:8) 1.0.1.8] Transport: [sip:192.168.70.62:5060]
    14:42:33.359 [CM503002]: Call(623): Alerting sip:10000@192.168.70.64:5060
    14:42:30.125 [CM503005]: Call(623): Forwarding: VoIPline:0060173672106@(Ln.10004@XeloQ)@[Dev:sip:727353@sip.goandcall.com:5060]
    14:42:30.125 [CM503024]: Call(623): Calling PSTNline:0173672106@(Ln.10000@Grandstream GXW-4104)@[Dev:sip:10000@192.168.70.64:5060]
    14:42:30.125 [CM503005]: Call(623): Forwarding: PSTNline:0173672106@(Ln.10000@Grandstream GXW-4104)@[Dev:sip:10000@192.168.70.64:5060, Dev:sip:10001@192.168.70.64:5062, Dev:sip:10002@192.168.70.64:5064, Dev:sip:10003@192.168.70.64:5066]
    14:42:15.609 [CM505001]: Ext.104: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 3.0.6061.0] Transport: [sip:192.168.70.62:5060]
    14:42:15.609 [CM503002]: Call(623): Alerting sip:104@192.168.70.91:1134;rinstance=1d898448b695d639
    14:42:15.093 [CM505001]: Ext.104: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.1.4.18] Transport: [sip:192.168.70.62:5060]
    14:42:15.093 [CM503002]: Call(623): Alerting sip:104@192.168.70.78:5060;transport=udp
    14:42:15.093 [CM505001]: Ext.105: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.1.5.15] Transport: [sip:192.168.70.62:5060]
    14:42:15.093 [CM503002]: Call(623): Alerting sip:105@192.168.70.60:5060;transport=udp
    14:42:15.093 [CM505001]: Ext.100: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.1.5.15] Transport: [sip:192.168.70.62:5060]
    14:42:15.093 [CM503002]: Call(623): Alerting sip:100@192.168.70.72:5060;transport=udp
    14:42:15.093 [CM505001]: Ext.106: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.1.5.15] Transport: [sip:192.168.70.62:5060]
    14:42:15.093 [CM503002]: Call(623): Alerting sip:106@192.168.70.76:5060;transport=udp
    14:42:15.078 [CM505001]: Ext.108: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.1.5.15] Transport: [sip:192.168.70.62:5060]
    14:42:15.078 [CM503002]: Call(623): Alerting sip:108@192.168.70.63:5060;transport=udp
    14:42:15.078 [CM505001]: Ext.110: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.1.5.15] Transport: [sip:192.168.70.62:5060]
    14:42:15.078 [CM503002]: Call(623): Alerting sip:110@192.168.70.70:5060;transport=udp
    14:42:15.078 [CM505001]: Ext.107: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.1.5.15] Transport: [sip:192.168.70.62:5060]
    14:42:15.078 [CM503002]: Call(623): Alerting sip:107@192.168.70.88:5060;transport=udp
    14:42:15.046 [CM505001]: Ext.109: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.1.5.15] Transport: [sip:192.168.70.62:5060]
    14:42:15.046 [CM503002]: Call(623): Alerting sip:109@192.168.70.68:5060;transport=udp
    14:42:15.031 [CM505001]: Ext.102: Device info: Device Identified: [Man: Grandstream;Mod: GXP Series;Rev: General] Capabilities:[reinvite, no-replaces, unable-no-sdp, recvonly] UserAgent: [Grandstream GXP2000 1.1.5.15] Transport: [sip:192.168.70.62:5060]
    14:42:15.031 [CM503002]: Call(623): Alerting sip:102@192.168.70.65:5060;transport=udp
    I have been looking for this solution for months. Your helps are much appreciated.
    Ryan
  4. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    18
    Hi rthee,
    First check your firmware version of grandstream. You need also to check the dial tones.
    Also do you consider of upgrading your PBX to the latest. They have been many changes / fixes and many improvements. Before uninstalling your current PBX, make a backup and uninstall. Then install the latest PBX http://www.3cx.com/phone-system/download-links/
    Install and restore your backup, and try again. If you need any assistance let me know.
    Thanks in advance.
  5. rthee
    Feb 9, 2010
    6
    Hi Michael,
    Thanks for your feedback.
    First, the firmware version of the grandstream phones are all up-to-date. The dial tone is using "pulse" mode.
    If I upgrade the 3CX PBX from v7.1 to v8.0, can I use same the license no.?
    Many thanks!
    Ryan
  6. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    18
    Hi Ryan,
    If your license entitles for upgrade insurance, yes you can. I would consider to upgrade even if it's expired.
    Check this link where we provide the build history from version 7 to version 8 latest.
    http://www.3cx.com/blog/change-log/
  7. rthee
    Feb 9, 2010
    6
    Hi Michael,
    I have upgraded it to version 8, and backed-up settings has been restored successfully. However, I can't access to Management Console page with default login details. Any ideas?
    I have done forward call testing during off-office hours; it seems not working either.
    Kindly need your advice. Many thanks.
    Regards,
    Ryan
