Solved Grandstream GXW4104 no incoming call
Discussion in '3CX Phone System - General' started by armandoangeles, Jan 17, 2017.
  1. armandoangeles
    Jul 28, 2015
    Is there someone encounter issue with GXW4104 regarding with incoming call?
    I am currently using the latest version of 3CX Phone 15, All the outgoing call run without any issue while the incoming call is the one has problem.
    If I dial the number attached on the gateway I can hear 2 ring and then busy tone.
    I tried to follow this link http://www.grandstream.com/sites/default/files/Resources/gxw410x_interop_3cx.pdf
    but did not work.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,811
    564
    Hello @armandoangeles
    Have you created an inbound rule for this gateway? Does the call reach the PBX? Set the logging to verbose by navigating to Dashboard/ Activity Log/ settings and set it to verbose. Restart all services.
    then try calling in and see if you are getting an error in the logs.
  3. armandoangeles
    Jul 28, 2015
    Hi @YiannisH_3CX
    Yes I created inbound rule for the Grandstream Gateway
    It seem that the call from the gateway did not reach on the 3CX Phone System, I can't find any activity log from the gateway to 3CX Phone system when I call the number attached on the gateway. (logging set to verbose already)
  4. armandoangeles
    Jul 28, 2015
    Hi @YiannisH_3CX
    I already resolved the issue, the problem relay on the Gateway GXW4104 configuration.
    - Navigate to Settings > Channel Settings
    - Under Calling to VoIP,
    + User ID = ch1-4:1001; <-- 1001 will be your extension destination on the 3CX Phone System
    + SIP Server = ch1-4:p1;
    + SIP Destination Port = ch1-4:5060;
    Andyshawn likes this.
  5. YiannisH_3CX
    May 10, 2016
    7,811
    564
    Glad to hear the issue is resolved and thank you for sharing your solution
  6. eav
    eav
    Oct 31, 2016
    I am facing an issue like that, but with outbound calls.
    Do you guys know what could be causing this?
    Thanks in advance.
