Grandstream GXW4104 VS Patton 4114 vs Audiocodes MP114/104
Discussion in '3CX Phone System - General' started by tsteffens, Jan 19, 2012.
  1. tsteffens
    Jul 14, 2011
    85
    Do you have a preference to these FXO gateway devices? We have used patton 4114 and while solid, it is similarly priced to Audiocodes and far more expensive than Grandstream.
    Anyone have experience with the others?
  2. danhriscanu
    danhriscanu New Member
    Nov 29, 2011
    232
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    Re: Grandstream GXW4104 VS Patton 4114 vs Audiocodes MP114/1
    I have the Grandstream 4104 in operation and I programmed pretty much according to the guide and so far, after 5 mnths of operation, no issues.
  4. Ian Joyce
    Oct 9, 2009
    51
    Audiocodes will work but is not supported so you are spending as much if not more money on an unsupported unit.
    Patton are very solid and probably the best solution but not as cost effective as the Grandstream
    The Grandstream is the most cost effective for sure, if you can get the unit working properly you really can save some money but the chances of running into an issue are often higher with these units.
  5. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    I'd go with the Grandstream as it is a much more cost effective solution in addition to it is a supported VoIP Gateway. I've only used once with no problems, I have deployed 3 Patton gateways with small hickups but Patton support is really on top of their game so the issues were solved pretty quickly. The only experiance I've had with Grandstream support was a disaster, and getting a response or to a live person is close to impossible.
