GRANDSTREAM GXW4104
Discussion in '3CX Phone System - General' started by kirimis, Oct 29, 2007.
  1. kirimis
    Oct 16, 2007
    43
    CAN ANYBOBY HELP WITH GRANDSTREAM GXW4104, I CAN NOT GET CALLER ID
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    What Caller ID type for you provider (Bellcore, ETSI, FSK, DTMF or etc)?
    If you don't know. You may try them one by one. Note, you must make sure that your telephone line have caller id function which enable by provider.
  3. kirimis
    Oct 16, 2007
    43
    GRANDSTEAM 4104
    CALLER ID IS COMING ON 3CX BUT NOT THE NUMBER OF THE CALLER BUT THE NUMBER OF MY OWN LINE
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Post your console log here. That may be help to speed up to fix your issue.
  5. kirimis
    Oct 16, 2007
    43
    caller id log
    16:34:38.671 StratInOut::eek:nHangUp [CM104007] Call(44): Call from Ln:10003@2310685230 to 209 has been terminated by Ln:10003@2310685230; cause: CANCEL; from IP:100.100.100.92
    this number is "2310685230" is my lines real number and i am calling from 2310683490
  6. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    what caller id is supported by your gateway and make sure your pstn provider is not blocking the caller id.
  7. kirimis
    Oct 16, 2007
    43
    reply
    Caller id is not blocked, if i put the line to analog phone i can see it
    DTMF is used by my provider, is there something i must change in grandstrem except DTMF option?
