Grandstream GXW4108 firmware V1.3.4.10
Discussion in '3CX Phone System - General' started by edujim, Apr 7, 2012.
  1. edujim
    Apr 6, 2012
    19
    I setup the Grandstream GXW4108 following the configuration guide, i also manually typed the Authentication password in channels section (step 5) of device configuration , I get the following errors on all ports except PORT 1 - which is Trunk 10000, submit, reboot (passwords supposed to be blank?) seems odd.
    step 10, outgoing rule, did this also with 0, doesnt seem to work, have to put a 9 and strip 1 digit then it works....
    12:23:48.848 [CM102001]: Authentication failed for SipReq: INVITE 10000@192.168.0.20 tid=8ef5c5020f940e30 cseq=INVITE contact=10007@192.168.0.150:5074 / 21184 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    12:23:30.599 [CM102001]: Authentication failed for SipReq: INVITE 10000@192.168.0.20 tid=ca62922402b23ef2 cseq=INVITE contact=10006@192.168.0.150:5072 / 11504 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    I tried a new topic earlier but it didnt work when i submitted! (seemed like a thesis) hope this enough info.
    EJ
    10,355
    223
    Are you setting up the gateway as one with multiple trunk groups, or one with one group, multiple trunk members?
  3. edujim
    Apr 6, 2012
    19
    leejor thanks for the reply...
    I'm guessing it's (1) PSTN gateway with multiple trunk groups. That's what it seems like on the configuration guide.
    http: //www.3cx.com/voip-gateways/Grandstream-GXW-41044108 - NO LONGER AVAILABLE, (followed it step by step)
    But I could be wrong.. I'm fairly new to this to be honest.. I'm coming from the Cisco UCM world.. go figure! im installing 3CX at my friends business. (1. 3cx is good,farily easy, affordable, all in one package 2. cisco is damn expensive amongst other bad things.
    EJ
  4. edujim
    Apr 6, 2012
    19
    going to try this again by removing passwords. on 3cx and grandstream.. just to test tomorrow..
    i will keep you posted.. i need to get this thing going asap.
    thanks again!
  5. GSSupport43
    Apr 16, 2012
    Could you please check once you configure and reboot the device that all the accounts are registered correctly from the status page of the GXW-410x ?
    Best Regards,
    GSSupport
