Grandstream GXW4200 Custom Template
Discussion in '3CX Phone System - General' started by eddv123, Oct 19, 2017.
  1. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,424
    187
    #1 eddv123, Oct 19, 2017
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    65
    The only gateway templates are for V14 and below. The forum does not allow posting of certain file types and it does check to see if the file does match the extension indicated. If you PM me with your email, I can get them to you.
    Martin.AIR and eddv123 like this.
  3. eddv123
    Aug 15, 2017
    1,424
    187
    Thanks lneblett, I have dropped you a PM.
  4. lneblett
    Sep 7, 2010
    2,086
    65
    did you get them?
  5. eddv123
    Aug 15, 2017
    1,424
    187
    Hi Ineblett,
    Yes got them, thanks very much!
