Grandstream HT-488 / 503
Discussion in '3CX Phone System - General' started by CKYang, Feb 11, 2008.
  1. CKYang
    Feb 11, 2008
    Hello
    Just wanted to find out, if I use more then one of the grandstream HT488 / 503 into a system ( I have two outside lines) will say grandstream A FXO be able to be routed to grandstream B FXS?
    I am trying to set this up in a small office of mine, with two outside lines and 5 internal, I am in IT and have experience with VoIP in general but not a VOIP PBX, please help..
    Thanks in advance.
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi CK,
    Yes. Grandstream A's FXO can be able to route to grandstream B's FXS. It will be apply to both HT488 and HT503.
    For HT503 can able to route its FXO to its FXS via 3CX box as well. However, HT488 cannot. HT503 supported incoming caller ID , HT488 cannot.
  3. CKYang
    Feb 11, 2008
    Hi, does that mean only the 503 can work with 3cx and not the 488? if so what should I be looking at when purchasing hardware so they work with 3cx.
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Both can work with 3CX.
    The different as below:
    HT503 support caller ID at FXO port. HT488 not support caller ID at FXO port.
