Grandstream HT 488 and Caller ID
Discussion in '3CX Phone System - General' started by Urbok, Apr 6, 2008.
  1. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    I've looked on a lot of messages of this forum. It's possible that 3cx dont support caller ID on HT 488?? and if I replace it with HT 503????
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    HT488 not support incoming caller ID only. NOT 3CX not support caller id from HT488. The specifications of HT503 support
    caller ID from both IP and PSTN. However, this feature at HT503 not work for me. I have try a few different type caller id (FSK, BELL and ETSI) analog phone lines. But no luck for HT503. All of them can be correctly decode the incoming caller by Grandstream GXW4104.
  3. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello Ricky,
    Caller Id does not work with me also
    Please can you help me to set the FXO because incoming calls open the call then ring in the extension and I can not make any call?
    FXS can make and receive calls
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Hi Amygoda,
    Do you mean when FXS port in-use, FXO port cannot make call out?
    Which call stage in use at HT503? One stage or two stage? Wait for dial tone or not?
