Grandstream HT 488
cjammer
After playing with it for months and a lot of reading, I have finally made the HT488 place calls to PSTN from the 3CX PBX and receive calls from PSTN to a 3CX PBX extension. Now I can be happy and move on to other experiments.
Has anyone else been able to get it to work like this?
Cjammer
I'm using HT-488 as well. However, I cannot make use it as PSTN gateway for place calls to PSTN from the 3CX PBX. Incoming calls are no problem. May I know how to config HT-488 as PSTN gateway for place calls to PSTN from the 3CX PBX?
PSTN number: 29070901
EXT number: 100
HT-488 internal number: 1000
Outbound Rule for HT-488 at 3CX PBX: 88 mask: 00rr
Prefix dail to PSTN at HT-488: 00
It works on this steps:
1. off hook EXT 100
2. dail 1000 (wait for the tone change)
3. dail 00 (wait for the tone change)
4. dail 29070901
Not works at normal step:
1. off hook EXT 100
2. Dail 88 29070901
I have a Couple page Document I typed up on configuring the HT-488.
I will post it to my website and you can get it from there.
It is a bit big to post in a forum box.
I will post the link when I get to it. It may be next week. So dont panic.
Getting Started - Admin
Dozer302
Get 3CX - Absolutely Free!
3CX
