GrandStream HT 503
Discussion in '3CX Phone System - General' started by tobiastromm, Dec 14, 2011.
  1. tobiastromm
    tobiastromm New Member
    Jun 26, 2010
    138
    Hi guys!
    I bought HT 503 and replace HT 488.
    Everything is working fine, except I am having some background noise when make and receive PSTN calls.
    Any idea about that?
    Thank You!
    10,371
    230
    Could be any number of things. "Background noise" is a bit vague, is it a hiss, echo, hollow, scratchy sound? Constant, or does it come and go? Do both parties (inside and out), hear it?
    Did you confirm that setting (PSTN Line, impedance..etc.) are set for your region of the world? Many SIP devices have defaults set for North America (depending on make).
  3. tobiastromm
    Jun 26, 2010
    138
    Leejor, always you :D
    Thank You for reply.
    Is it a hiss.
    Constant, start at the moment I open PSTN line.
    Just inside (HT 503 site) can hear it.
    I have some difficult about that, but I'm working.
  4. leejor
    10,371
    230
    On page 34, of the manual, settings near the middle of the page, Country-Based and Impedance-Based settings, you might want to see if those are correct for your PSTN provider. If you do a search, someone may have the correct settings for your country. There may be a gain setting that can be tweaked too. Just do one at a time and make note of the settings before you change anything.
  5. tobiastromm
    Jun 26, 2010
    138
    Leejor.
    I find that: http://www.3amsystems.com/wireline/daa-search.htm?country=Brazil&ppd=&mbr=&pps=&idt=&dtmfPwr=&dtmfCad=&ringFreq=&ringV=&ringThr=&ringZ=&onHookV=&minOnHook=&minOffHook=&minBDD=&maxAWT=&txPwr=&callerID=&bt=&ct=&gt=&term=&typeApproval=&advisoryNote=&regBody=&specDocs=
    I'm already using this value for impedance.
    Try all values, but don´t solve.
  6. leejor
    10,371
    230
    I wonder if it is related to firmware.....http://forums.grandstream.com/forums/index.php?topic=8276.0
  7. tobiastromm
    Jun 26, 2010
    138
    Leejor,
    can you download files and see diference HT 488 x HT 503:
    https://skydrive.live.com/redir.aspx?cid=b5a521f906064abb&resid=B5A521F906064ABB!135&parid=root
  8. leejor
    10,371
    230
    I can hear a bit of noise in the 503 wave file. If you have all other settings the same as the 488, you may want to pursue this on the Grandstream forum as it is not really a 3CX issue and may be something to do with the firmware release that you are currently using. Someone there may be able to confirm that for you.
