Grandstream HT267 for Faxing Outbound
Discussion in '3CX Phone System - General' started by craigreilly, Jul 1, 2013.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,962
    180
    We have just setup a fax machine using an HT287. When we send faxes a lot of the machines come back with Dirty Line errors and the fax is not sent.
    There is 1 fax that we send to which is built into a photo copier at a large office and do not get the line error.
    We use NexVortex for our provider.
    Grandstream:
    Software Version: Program-- 1.1.0.45 Bootloader-- 1.1.0.1 HTML-- 1.1.0.45 VOC-- 1.0.0.13
    Can anyone shed some light on tweaks I may need to make to the 267 - or perhaps another adapter I should be instead using...
    Thank you in advance.
    10,365
    227
    I've been using a SPA2102 for the machine and a 3102 as the PSTN gateway. So far, with a few machines it all works well (fingers crossed). Some newer machines, may have problems dropping down to a low enough speed. Some older machines may not be able to compensate for errors, it's a bit of a gamble.
  3. markshehan
    markshehan New Member
    Nov 14, 2012
    141
    As Leejor said the SPAs work
    But we have 100% success rate when our customers use the Grandstream HT502 with many different fax machines and all-in-ones. 99% go through first time and the rest go through on a redail as the first failure is usually just a "normal" fax failure that you can get with analog lines.
  4. craigreilly
    Feb 1, 2012
    2,962
    180
    I have setup Fax Device (Grandstream) for Passthru rather than T38 and it seems to work better - but it seems slow as heck for a 1 page fax... say 3 minutes.
  5. leejor
    10,365
    227
    Probably slowing down to a speed that passed during the initial "handshake". Which tells you that errors had been encountered when higher speeds were attempted.
  6. markshehan
    Nov 14, 2012
    141
    Can you run a wireshark? Should see the packets going through and can see if they are sending more than receiving
    What was wrong with T38?
  7. craigreilly
    Feb 1, 2012
    2,962
    180
    T38 did not work at all - always got dirty line conditions during the fax and it did not go thru. Atleast with Pass-Thru the faxes are making it...
    I just looked at their server activity log and the last fax picked up at 15:08:40 and ended at 15:09:48. That seems pretty quick to me.
    I will drum up a wireshark.
