Grandstream HT702
looker44
I have added a HT702 successfully BUT nothing shows in VOIP/PSTN Gateways for that device
extension rings and i can dial out
Looker, the device is an FXS adapter, as such, you will see the ports logged in under Phones. Only FXO/ISDN/PRI devices will show up under VoIP PSTN Gateway. You are well setup.
i thought that would be the case, just wanted to check since i had to set it up under the gateway section
MANY THANKS
Getting Started - Admin
Hammad.k
Get 3CX - Absolutely Free!
3CX
