gluetome
- Joined
- Nov 27, 2018
- Messages
- 35
- Reaction score
- 0
This is a link for installing HTXXX FXS gateways
https://www.3cx.com/voip-gateways/grandstream-ht-fxs/
In the steps to set up the gateway, there is a step where it is recommended that a phone is connected to determine the IP address for the gateway. I realised after spending an extra $30 spent on buying an analog phone that it is not required.
Connect the LAN port of gateway to your computer and log in to the web page of the gateway. Once the configuration is uploaded on to the gateway and an IP address is allocated it is visible from the FXS tab of gateway webpage. Or once the configuration is uploaded you don't need the gateway webpage anymore.
Switch the cable to the wan port of the gateway and it will be visible in the Management Console.
3CX guides are very very well written and got the job done.
I had to resort to this method as when I was trying to get the IP address from pressing *** 02 on the phone it kept reading the IP address as 0.0.0.0
