Grandstream on V15
Discussion in '3CX Phone System - General' started by neville, May 4, 2017.
  1. neville
    neville New Member
    Apr 23, 2012
    222
    39
    First, I know that Grandstream is no longer supported. However, I have a legacy client with about 100 GS 2130's and GS 2160's that has decided to keep those, even if it means staying on an older version of 3CX. I have them working fine in my lab on V15, including software upgrades, park, etc. Only issue so far is some of the CTI features which the client does not use.
    I would like to know if anyone has upgraded a production environment to V15 using these GS phones and if so how it is working out.
    Any info is appreciated.
  2. aberry
    aberry New Member
    Jan 13, 2015
    119
    7
    I'm running about 150 GXV 3275 and GXV3240 and they are a pain. Got them working pretty well from the provisioning / config side. The problems with those models are related to the firmware and issues from the manufacturer. Occasionally these phones refuse to register, or register incorrectly until they are rebooted. I have been slowly replacing those phones with Snom units. Not as many features, but at least they just work.
