Grandstream Phone - RECORD CALL
Discussion in 'Ideas' started by craigreilly, Apr 12, 2018.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,591
    309
    Tested on 2170
    Manually added a RECORD button.
    It would be nice if the display could show a recording actually started.
    If you accidentally hit it twice, you may not realize it and not record the call.
