Grandstream Stability: firmware 1.1.6.16
Discussion in '3CX Phone System - General' started by darrellchapman, Apr 11, 2008.
  1. darrellchapman
    Nov 26, 2007
    268
    If anyone is using Grandstream GXP phones, I'd highly recommend that you upgrade to v1.1.6.16 of the firmware. This firmware combined with the recent update to 3CX server (build 4393) makes for a very stable platform. Line appearance, extension appearance, BLF, and other presence buttons work flawlessly now.
    Also, DMTF generation problems have been eliminated in this firmware upgrade.
  2. Philco
    Philco Member
    Nov 10, 2007
    364
    HI Darrell, hope the little one is OK.
    Been trying the BLF on GXP series and seems ok on our test set up, though have you seen Andy's(Silentfun) post on the GXP upgrade, Ive not noticed this so far.
    http://www.3cx.com/forums/gxp-2020-blf---bug-in-firmware-4929.html
    Phil
  3. darrellchapman
    Nov 26, 2007
    268
    He's doing well. Thanks Phil.
    No, I haven't seen this post. I'm not having any problems like this though. I'll look more in to it when I get a chance.
