Grandstream Transfer BLF
Discussion in '3CX Phone System - General' started by Barry O'Reilly, Mar 2, 2018.
  1. Barry O'Reilly
    Feb 9, 2018
    Trying to figure out how 3CX is passing the below config to the phones when that P Value doesn't seem to be in the 3CX supported templates for grandstream. I've created a new template for a 2135 and set this P value to 0 but it's getting overwritten somehow.
    Enable transfer via non-Transfer MPK. 0 - No, 1 - Yes. Default is 0
    <!-- Number: 0,1 -->
    <!-- Mandatory -->
    <P22162>1</P22162>
    We use grandstream for all our installs and want to be able to use attended transfer and blind transfer with the help of using BLF's but it looks like you have to select either attended or blind if you want to use BLF's to transfer.
  2. manfer
    Oct 19, 2017
    49
    8
    That P value is included on the grandstream template grandstrean.ph.xml which is the one used for the GXP2135 model and its value is 1 on that template. It is on line 2610 on file granstream.ph.xml.
