Grandstream XML PhoneBook
Discussion in '3CX Phone System - General' started by scottyork, Jun 6, 2007.
  1. scottyork
    Jun 1, 2007
    64
    While we're waiting for the TAPI integration feature, can anyone point me in the direction of a utility that will convert an Outlook contacts folder to the correct XML phonebook format for Grandstream. Then at least I can provide some automated dialing for users.
    I'm contemplating coding something to convert an exported CSV file but don't want to "re-invent the wheel".
