- Joined
- Sep 22, 2008
- Messages
- 17
- Reaction score
- 0
I have the above gateway & configured it according to the guide from 3cx.
I have 1 pstn line plugged in.
When I dial the call terminates immediately & I get the following in the server log:-
12:23:52.465 Call::Terminate [CM503008]: Call(3): Call is terminated
12:23:52.465 Call::RouteFailed [CM503015]: Call(3): Attempt to reach [sip:[email protected]] failed. Reason: Server Failure
12:23:52.465 CallLeg:nFailure [CM503003]: Call(3): Call to sip:[email protected]:5060 has failed; Cause: 503 Service Unavailable; from IP:192.168.15.3:5060
12:23:52.356 CallLeg:nFailure [CM503003]: Call(3): Call to sip:[email protected]:5060 has failed; Cause: 503 Service Unavailable; from IP:192.168.15.3:5060
12:23:52.247 CallLeg:nFailure [CM503003]: Call(3): Call to sip:[email protected]:5060 has failed; Cause: 503 Service Unavailable; from IP:192.168.15.3:5060
12:23:52.137 CallLeg:nFailure [CM503003]: Call(3): Call to sip:[email protected]:5060 has failed; Cause: 503 Service Unavailable; from IP:192.168.15.3:5060
12:23:52.044 CallCtrl:nSelectRouteReq [CM503004]: Call(3): Calling: PSTNline:01883624228@(Ln.10000@Grandstream VOIP Gateway)@[Dev:sip:[email protected]:5060, Dev:sip:[email protected]:5062, Dev:sip:[email protected]:5064, Dev:sip:[email protected]:5066]
12:23:52.044 CallCtrl:nSelectRouteReq [CM503010]: Making route(s) to [sip:[email protected]]
This looks like a Granstream issue?
The four lines are all green on the 3cx control panel.
If I dial in the phone just rings and never picks up.
I haven't a scooby about any of this so am floundering about quite a lot, so any help greatly appreciated.
