Granstream need
Discussion in '3CX Phone System - General' started by craigreilly, Mar 23, 2018.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,591
    309
    Dear support,
    Please consider separating Default Ring Tone in the Provisioning Setup for separate Internal/External Ring Tones at minimum.
