Granular control of rights
Discussion in 'Ideas' started by brian-le, Nov 11, 2017.
  1. brian-le
    Sep 8, 2016
    17
    Right now I have an open support ticket for extension configurations being erased partially. It was suggested that a receptionist user could be clearing the extension. In my case that's not the issue but Assign and Clear shouldn't be part of the receptionist operations rights. It would be far better if each function was a separate right. Or at the very least split out user control functions and assign and clear. I can't give anyone receptionist rights because they might accidentally clear the extension.
