Granular security changes for 3cx Management Console
Discussion in 'Ideas' started by tratz, Feb 29, 2016.
  1. tratz
    tratz New Member
    Oct 21, 2015
    111
    16
    I would like the ability to setup granular security changes within 3cx. Namely the ability for users or supervisors can modify only certain fields (forwarding rules, or status) versus every change within the extension. We are running into a problem where senior staff wants recordings but we don't want supervisors to modify those sections and having helpdesk make changes is rather annoying.
