gray extensions/lines
Discussion in 'Windows' started by asfuture, May 7, 2008.
  1. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    i have a problem with the last VoIP Client. all mijn extensions are gray. and they are not changing if i go to use them. i'm using 5.1.4132.0 version
  2. coelhopsi
    May 7, 2008
    84
    I'm using version 5.1.4492 and I am also facing the same problem. All extensions are grey... not even mine is green!
    Is there anything that should be configured in the client or in the server?
  3. coelhopsi
    May 7, 2008
    84
    Hey.... I've just found this on the following thread: http://www.3cx.com/forums/no-extensions-5110.html
    I'm using the free version, but since you're using a version older than 4393, maybe that wouldn't be the case...
  4. coelhopsi
    May 7, 2008
    84
  5. demonofsteel
    demonofsteel New Member
    Mar 28, 2008
    105
    on top of the fact that free versions (excluding build 4493) can't see extensions satus, you must also keep in mind that you need to use the same client version as the server version (except client 4492 with server 4510) even if you have a licence.
  6. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    i have the enterprise edition of 3CX. and the 3CX VOIP client version 5.1.4492 from 15 April 2008
  7. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    it's resolve. i installed a free version. it was my fout. but now is ok.
  8. asfuture
    asfuture New Member
    Aug 3, 2007
    156
    thats right teh point Maalandis. the last one i didn't do anythink about this (no retyping) and it's working.... it saw the key
