group id display on the phone
Discussion in '3CX Phone System - General' started by frenchy, Jul 14, 2009.
  1. frenchy
    Aug 27, 2007
    23
    Is it possible to change the name of identity of calling it on the display of phones LinkSys 962 to make show the number of calling it preceded by the name of the group of distribution ?
    Regards,
    François
  2. wzaatar
    Aug 1, 2007
    90
    Essaye de changer l'option "Outbound Caller ID" dans la configuration de l'extension, onglet "Other Options".
    Try to change the option "Outbound Caller ID" in the extension configuration menu, under the "Other Options" tab.
    Cheers,
    W.
