Solved Group set to use 2nd Trunk showing CID for 1st Trunk
Discussion in '3CX Phone System - General' started by tastycoders, Mar 8, 2018.
Tags:
  1. tastycoders
    Mar 6, 2018
    19
    Hi! I have something odd occurring. I have two trunk setup to be used separately for two groups for both inbound and outbound calling.
    Trunk1 - CID *9091
    Trunk 2 - CID *0188
    Group1 inbound and outbound rules to use Trunk1
    Group2 inbound and outbound rules to use Trunk2
    I have no issues with Trunk 1 and Group 1
    Group2 - If I call their main DID it calls the extension set in Group2 with no issues.
    If I call from an extension in Group2 the caller ID is CID *9091 from Trunk 1.
    Outbound Rule for Group2:
    https://www.screencast.com/t/xrTPRDkbKeY1
    caller ID for Trunk 2:
    https://www.screencast.com/t/Ig2U2zyLL
    Everything seems right.
    Why would it have the caller ID for Trunk 1 when group2 dials out?
    Lost.
    Thank you in advance.
    -Jason
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,313
    249
    Check that the trunk is indeed using the trunk CID and not the extension CID...
  3. tastycoders
    Mar 6, 2018
    19
  4. craigreilly
    Feb 1, 2012
    3,313
    249
    Is there a caller id in the extension - i'm heading that direction. we use Flowroute, and caller id is coming from the Extension level, not the trunk level.
    but strange that internal calls are using the caller id and not the extension number.
  5. tastycoders
    Mar 6, 2018
    19
    No caller ID at the Extension or Group level. Let me try that.
    craigreilly likes this.
  6. craigreilly
    Feb 1, 2012
    3,313
    249
    "From Display Name" if I recall under Trunk Outbound Parameters
  7. tastycoders
    Mar 6, 2018
    19
    I set the caller ID at the extension level and that worked.
  8. tastycoders
    Mar 6, 2018
    19
    @craigreilly I want to thank you for all your help.
    I really wish I didn't have to put CID at the ext level. It would be way better at a Group level =)
    -J
