Group Voicemail Record Prompt
Discussion in '3CX Phone System - General' started by Elliot Cater, Jan 19, 2018.
  1. Elliot Cater
    Aug 29, 2017
    18
    I've been trying to find a definitive answer for this. How would you record a group voicemail prompt for a ring group?
    Cheers
    Elliot
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    38
    Hello @Elliot Cater
    If you want to forward Ring Group unanswered calls to a voicemail, you need to create a dummy extension for this and in the Ring Group Settings >> "Destination if no answer" forward it to the voicemail of that extension. Now on the dummy extension Settings >> Voicemail, under "Manage Voicemail Greetings" record the prompt that you want the callers to hear.
  3. Elliot Cater
    Aug 29, 2017
    18
    Thanks for the reply.
    This whole ring group voicemail seems like a bit of a hack. It's a shame the voicemail can't be forwarded to all the extensions from a ring group, instead of just firing an email to everyone in the group.
    jbryant84 and jimbo59 like this.
  4. jimbo59
    jimbo59 Member
    Nov 17, 2017
    357
    77
    Put in a feature request.
