Group wake up calls
Discussion in 'Ideas' started by MarkLilly, Dec 13, 2017.
  1. MarkLilly
    Oct 21, 2016
    6
    Is it possible (via the web client) to select a number of extensions and create a wake up call rather than doing it one by one.
    The situation is I have installed 3cx with 90 odd extensions into a hotel.
    This hotel have groups of tourists coming in occupying say 40 of the rooms and they all need a wake up call at the same time. So rather than the reception doing it one by one, is it possible to select 40 and create the wake up call.
  2. Goga
    Mar 31, 2017
    16
    Is it possible ? We also get esquire about this .
  3. Aronsson
    Mar 12, 2018
    Would really preciate a solution for this
  4. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    722
    123
    It is possible to create wake up calls via the 3CX Call Control API. You could build a separate web page for this purpose. I envision a list box of extensions (rooms) with a checkbox next to each extension. You select the desired extensions, then configure the wake up call settings, and press apply. We could probably flag the extension to reflect that a wake up call is configured. You could probably configure a date range as well, so you create wake up calls spanning several days if needed. If you wanted to get fancy, we could probably provide a calendar interface as well.
  5. VITS 3CX
    Mar 12, 2018
    17
    how is it possible to create wake up calls via the 3CX Call Control API
