group will not ring
Discussion in '3CX Phone System - General' started by spec, Sep 29, 2006.
  1. spec
    Sep 8, 2006
    51
    I currently have 3 extensions set up for testing which are registered to one ring group and have all incoming calls set to that group. I just changed the incoming from group to one extension and the extension rang. Changed it back to group ring and again none of the extensions would ring.
    The extension are showing as registered at the time of calling.
    thanks
  2. spec
    Sep 8, 2006
    51
    As there has been on response over the last few days can I assume you are unable to resolve this problem???
    thanks
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    Group ringing
    Are you calling from an outside line? PSTN line or VOIP provider line? Or are you just calling the group from an internal extension? Do you have any info showing up in the server status page?
  4. Nick Galea
    Jun 6, 2006
    1,994
    304
    Groups are working in the latest beta
    the issue has been fixed in the latest beta. Thank you for your feedback
  5. cjammer
    cjammer New Member
    Dec 21, 2006
    109
    Group wont ring
    I downloaded the latest Beta and I am having the same problem with a ext not rining a group. I have 3 extensions and two are in the group. I set it to ring all and in the calling extension you can hear the ring, but the others do not ring.
    Any Ideas?
