- Joined
- Oct 15, 2012
- Messages
- 13
- Reaction score
- 1
Given that the whole point behind the 3cx tunnel is to make one way audio and NAT issues cease to exist, I at a loss to understand why I can hear people but they cannot hear me when I use the tunnel on 3G or WiFi external connections.
Even more odd, If I go hunting around and locate the V2 andriod client, everything is fine, although call quality and latency is horrible.
So, V10, V11, and V12 - all work great on an internal wifi connection, on GS1 standard, GS1 with DarkyRom, GS3 and GS3 mini.
All of those versions and phones all have one way audio when used on any external connection, but all work both ways on the V2 Android client.
The only NAT rule is TCP5090 to avoid getting hacked on 5060.
The PBX has Stun disabled and the external IP entered.
PBX delivers Audio option doesn't fix the trouble.
So what is different about V2 that makes it work when all the newer ones do not?
Why would something build for the purpose of removing the issue be causing the issue?
Andrew
Andrew
