GSM Gateway Altesys ALT1500
Discussion in '3CX Phone System - General' started by StefanoZak, Jun 6, 2007.
  1. StefanoZak
    Jun 5, 2007
    I'm testing this cheap VOIP GSM Gateway with 3CX, no problem receiving calls from GSM Network, I'm not able to place outgoing calls via GSM.
    In the user manual there is an example only for Asterisk:
    It is very important to use only ulaw or alaw when DTMF is Inband.
    So if you want to be able to do some DISA when you call from GSM to
    Asterisk, it has to be one of these 2 codecs.
    16.5 sip.conf
    ; GSM VOIP Gateway
    [103]
    type=friend
    username=103
    fromuser=103
    regexten=103 ; When they register, create extension 401
    secret=xxxxxxx ; Asterisk extension password
    context=gateway ; Incoming calls context
    dtmfmode=inband ; Very important for DISA to work
    call-limit=1 ; Limit to 1 call max
    callerid=GSM Gateway <103>
    host=dynamic
    nat=no ; Gateway is not behind a NAT router
    canreinvite=no ; Typically set to NO if behind NAT
    insecure=very
    qualify=yes
    disallow=all
    allow=ulaw ; prefered codec for DTMF detection
    allow=alaw
    GSM Gateway User manual
    -23-
    16.6 extensions.conf
    ; ******* GSM Gateway incoming calls **********
    [gateway]
    exten => _103,1,Answer()
    exten => _103,2,DigitTimeout(3) ; give enough time to do second stage dialing
    exten => _103,3,ResponseTimeout(5)
    exten => _103,4,DISA(no-password|outgoing) ; here 'outgoing' is the normal context to deal
    with the dial plan
    [outgoing]
    ; example of LAN to GSM call
    ; call the GSM Gateway sim card mail box throug GSM
    exten => _888,1,SetCallerID("xxxxxxxxxx")
    exten => _888,2,Dial(SIP/${EXTEN}@103,60,r)
    exten => _888,3,Hang
    The gateway is up an running receiving calls (PSTN gateway in 3cx, rules, auth ....), but non in outgoing call, any suggests for dialing?
    Regards
    Stefano
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,916
    225
    Please post your server status log, then we can let you know why the outbound call is not going out....
  3. StefanoZak
    Jun 5, 2007
    Hi Nick,
    here the log of ougoing call from ext 108 with rule 9 for GSM GW:
    19:42:35.434|ServerAuthManager.cxx(47)|Trace5|Resip|>>:ServerAuth requested credentials SipReq: REGISTER 192.168.10.76 tid=909c8ad10ecf08684b9833fe8ecff3ac cseq=REGISTER contact=10001@192.168.10.242:5060 / 4 from(wire)
    19:42:35.434|ServerAuthManager.cxx(125)|Trace5|Resip|>>:Checking for auth result in realm=3CXPhoneSystem A1=
    19:42:35.434|ServerAuthManager.cxx(210)|Trace5|Resip|>>:Authorized request for 3CXPhoneSystem
    19:42:35.434|.\Authorization.cpp(257)|Trace5|Authorization|AuthMgr::eek:nAuthSuccess:Caller <sip:10001@192.168.10.76>;tag=56db20ea has been authenticated successfully
    19:42:35.434|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipReq: REGISTER 192.168.10.76 tid=909c8ad10ecf08684b9833fe8ecff3ac cseq=REGISTER contact=10001@192.168.10.242:5060 / 4 from(wire)
    19:42:35.434|ServerRegistration.cxx(214)|Trace5|Resip|>>:Adding sip:10001@192.168.10.76 -> <sip:10001@192.168.10.242:5060>
    19:42:35.554|.\Registrar.cpp(81)|Trace5|Registrar|ServRegs::eek:nAdd:Got registration from Ln:10001@Altesys;
    Contacts: [<sip:10001@192.168.10.242:5060>]
    19:42:35.554|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: OnHook; DN 10001
    19:42:35.554|.\Registrar.cpp(83)|Log2|Registrar|ServRegs::eek:nAdd:Registered: Ln:10001@Altesys
    19:42:35.554|ServerRegistration.cxx(42)|Trace5|Resip|>>:accepted a registration sip:10001@192.168.10.76
    19:42:56.875|ServerAuthManager.cxx(307)|Trace5|Resip|>>:Requesting credential for linksysspa3102 @ 3CXPhoneSystem
    19:42:56.995|Helper.cxx(865)|Trace5|Resip|>>: username=linksysspa3102 password=carpediem realm=3CXPhoneSystem method=REGISTER uri=sip:192.168.10.76 nonce=12825624851:685cac192583ca48c05237cb364f291c
    19:42:56.995|ServerAuthManager.cxx(47)|Trace5|Resip|>>:ServerAuth requested credentials SipReq: REGISTER 192.168.10.76 tid=-1eadcccb cseq=REGISTER contact=10000@192.168.10.243:5061 / 34165 from(wire)
    19:42:56.995|ServerAuthManager.cxx(125)|Trace5|Resip|>>:Checking for auth result in realm=3CXPhoneSystem A1=
    19:42:56.995|ServerAuthManager.cxx(210)|Trace5|Resip|>>:Authorized request for 3CXPhoneSystem
    19:42:56.995|.\Authorization.cpp(257)|Trace5|Authorization|AuthMgr::eek:nAuthSuccess:Caller "SPA-3102"<sip:10000@192.168.10.76>;tag=f6f9ea58c587do1 has been authenticated successfully
    19:42:56.995|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipReq: REGISTER 192.168.10.76 tid=-1eadcccb cseq=REGISTER contact=10000@192.168.10.243:5061 / 34165 from(wire)
    19:42:56.995|ServerRegistration.cxx(214)|Trace5|Resip|>>:Adding sip:10000@192.168.10.76 -> "SPA-3102"<sip:10000@192.168.10.243:5061>;expires=60
    19:42:56.995|ServerRegistration.cxx(42)|Trace5|Resip|>>:accepted a registration sip:10000@192.168.10.76
    19:43:27.249|TuSelector.cxx(70)|Trace5|Resip|>>:Stats message
    19:43:55.199|ServerAuthManager.cxx(307)|Trace5|Resip|>>:Requesting credential for linksysspa3102 @ 3CXPhoneSystem
    19:43:55.299|Helper.cxx(865)|Trace5|Resip|>>: username=linksysspa3102 password=carpediem realm=3CXPhoneSystem method=REGISTER uri=sip:192.168.10.76 nonce=12825624851:685cac192583ca48c05237cb364f291c
    19:43:55.299|ServerAuthManager.cxx(47)|Trace5|Resip|>>:ServerAuth requested credentials SipReq: REGISTER 192.168.10.76 tid=-639febba cseq=REGISTER contact=10000@192.168.10.243:5061 / 34166 from(wire)
    19:43:55.299|ServerAuthManager.cxx(125)|Trace5|Resip|>>:Checking for auth result in realm=3CXPhoneSystem A1=
    19:43:55.299|ServerAuthManager.cxx(210)|Trace5|Resip|>>:Authorized request for 3CXPhoneSystem
    19:43:55.299|.\Authorization.cpp(257)|Trace5|Authorization|AuthMgr::eek:nAuthSuccess:Caller "SPA-3102"<sip:10000@192.168.10.76>;tag=f6f9ea58c587do1 has been authenticated successfully
    19:43:55.299|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipReq: REGISTER 192.168.10.76 tid=-639febba cseq=REGISTER contact=10000@192.168.10.243:5061 / 34166 from(wire)
    19:43:55.299|ServerRegistration.cxx(214)|Trace5|Resip|>>:Adding sip:10000@192.168.10.76 -> "SPA-3102"<sip:10000@192.168.10.243:5061>;expires=60
    19:43:55.309|ServerRegistration.cxx(42)|Trace5|Resip|>>:accepted a registration sip:10000@192.168.10.76
    19:44:27.246|TuSelector.cxx(70)|Trace5|Resip|>>:Stats message
    19:44:53.504|ServerAuthManager.cxx(307)|Trace5|Resip|>>:Requesting credential for linksysspa3102 @ 3CXPhoneSystem
    19:44:53.624|Helper.cxx(865)|Trace5|Resip|>>: username=linksysspa3102 password=carpediem realm=3CXPhoneSystem method=REGISTER uri=sip:192.168.10.76 nonce=12825624851:685cac192583ca48c05237cb364f291c
    19:44:53.624|ServerAuthManager.cxx(47)|Trace5|Resip|>>:ServerAuth requested credentials SipReq: REGISTER 192.168.10.76 tid=-9c57585d cseq=REGISTER contact=10000@192.168.10.243:5061 / 34167 from(wire)
    19:44:53.624|ServerAuthManager.cxx(125)|Trace5|Resip|>>:Checking for auth result in realm=3CXPhoneSystem A1=
    19:44:53.624|ServerAuthManager.cxx(210)|Trace5|Resip|>>:Authorized request for 3CXPhoneSystem
    19:44:53.624|.\Authorization.cpp(257)|Trace5|Authorization|AuthMgr::eek:nAuthSuccess:Caller "SPA-3102"<sip:10000@192.168.10.76>;tag=f6f9ea58c587do1 has been authenticated successfully
    19:44:53.624|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipReq: REGISTER 192.168.10.76 tid=-9c57585d cseq=REGISTER contact=10000@192.168.10.243:5061 / 34167 from(wire)
    19:44:53.624|ServerRegistration.cxx(214)|Trace5|Resip|>>:Adding sip:10000@192.168.10.76 -> "SPA-3102"<sip:10000@192.168.10.243:5061>;expires=60
    19:44:53.634|ServerRegistration.cxx(42)|Trace5|Resip|>>:accepted a registration sip:10000@192.168.10.76
    19:45:02.206|ServerAuthManager.cxx(363)|Trace5|Resip|>>:Sending challenge to SipReq: INVITE 93287529064@192.168.10.76 tid=ad943a3588da1635 cseq=INVITE contact=108@192.168.10.128 / 44433 from(wire)
    19:45:02.206|ServerAuthManager.cxx(41)|Trace5|Resip|>>:ServerAuth challenged request SipReq: INVITE 93287529064@192.168.10.76 tid=ad943a3588da1635 cseq=INVITE contact=108@192.168.10.128 / 44433 from(wire)
    19:45:02.316|ServerAuthManager.cxx(307)|Trace5|Resip|>>:Requesting credential for 108 @ 3CXPhoneSystem
    19:45:02.326|Helper.cxx(865)|Trace5|Resip|>>: username=108 password=108001 realm=3CXPhoneSystem method=INVITE uri=sip:93287529064@192.168.10.76 nonce=12825625502:8ee085a6dc21bee91d4a70801aaafcea
    19:45:02.326|ServerAuthManager.cxx(47)|Trace5|Resip|>>:ServerAuth requested credentials SipReq: INVITE 93287529064@192.168.10.76 tid=d6b4c54554c41c45 cseq=INVITE contact=108@192.168.10.128 / 44434 from(wire)
    19:45:02.326|ServerAuthManager.cxx(125)|Trace5|Resip|>>:Checking for auth result in realm=3CXPhoneSystem A1=
    19:45:02.326|ServerAuthManager.cxx(210)|Trace5|Resip|>>:Authorized request for 3CXPhoneSystem
    19:45:02.326|.\Authorization.cpp(257)|Trace5|Authorization|AuthMgr::eek:nAuthSuccess:Caller "StefanoGS"<sip:108@192.168.10.76>;tag=bd5810a06271e409 has been authenticated successfully
    19:45:02.326|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipReq: INVITE 93287529064@192.168.10.76 tid=d6b4c54554c41c45 cseq=INVITE contact=108@192.168.10.128 / 44434 from(wire)
    19:45:02.326|.\CallMgr.cpp(285)|Trace5|CallControl|ADSFactory::createAppDialogSet:Creating ADS for INVITE
    19:45:02.326|.\CallConf.cpp(405)|Trace5|CallControl|CallConf::CallConf:Call created: C:3B
    19:45:02.326|.\CallConf.cpp(348)|Trace5|CallControl|CallConf::addCallLeg:Added leg# 1 to call C:3B
    19:45:02.326|.\Call.cpp(1322)|Trace5|CallControl|CallLegImpl::CallLegImpl:Leg @L:1@C:3b is created
    19:45:02.326|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_Start -> UAS_Offer
    19:45:02.326|.\ISHandler.cpp(21)|Trace5|CallControl|ISHandler::eek:nNewSession:Incoming: sis=7156;oat=Offer;rl=INVITE sip:93287529064@192.168.10.76 SIP/2.0
    19:45:02.336|.\Endpoint.cpp(32)|Trace5|Endpoint|Endpoint::findSource:Settings for caller is found: CfgExt:108
    19:45:02.336|.\Call.cpp(122)|Trace5|CallControl|CallLegImpl::eek:nIncoming:Endpoint is built: Ext.108
    19:45:02.386|.\Call.cpp(661)|Trace5|CallControl|CallLegImpl::initMSEndpoint:Created internal MS endpoint for Ext.108: addr=192.168.10.76:7210
    19:45:02.386|ServerInviteSession.cxx(91)|Trace5|Resip|>>:UAS_Offer: provisional(100)
    19:45:02.386|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_Offer -> UAS_EarlyOffer
    19:45:02.386|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend:InviteSession(7156) sends SIP/2.0 100 Trying
    19:45:02.386|.\CallConf.cpp(95)|Log2|CallControl|CallConf::eek:nIncoming:Call(C:3B): Incoming call from Ext.108 to sip:93287529064@192.168.10.76
    19:45:02.386|.\CallStrategies.cpp(415)|Trace5|CallManager|StratInOut::initialize:Initialize InOut call strategy
    19:45:02.497|.\DBAccessor.cpp(1033)|Trace5|DataBase|DBPostgressAccessor::findDestinationsEx:Will use outbound rule rule ID=5
    19:45:02.627|.\CallTarget.cpp(359)|Trace5|CallManager|CT_Lines::selectNextTarget:Select new line for outbound call
    19:45:02.657|.\Call.cpp(661)|Trace5|CallControl|CallLegImpl::initMSEndpoint:Created internal MS endpoint for Ln:10001@Altesys: addr=192.168.10.76:7212
    19:45:02.657|.\CallConf.cpp(348)|Trace5|CallControl|CallConf::addCallLeg:Added leg# 2 to call C:3B
    19:45:02.657|.\Call.cpp(1322)|Trace5|CallControl|CallLegImpl::CallLegImpl:Leg 10001@L:2@C:3b is created
    19:45:02.657|.\CallTarget.cpp(372)|Trace5|CallManager|CT_Lines::selectNextTarget:Line Ln:10001@Altesys is found for outbound call
    19:45:02.667|.\CallConf.cpp(107)|Trace5|CallControl|CallConf::eek:nIncoming:MediaServer could be used for this call
    19:45:02.667|.\ISHandler.cpp(157)|Trace5|CallControl|ISHandler::eek:nOffer:Offered: is=7156; rl=INVITE sip:93287529064@192.168.10.76 SIP/2.0
    19:45:02.667|.\CallStrategies.cpp(605)|Trace5|CallManager|StratInOut::eek:nOffer:InOut: got offer from 108@L:1@C:3b
    19:45:02.667|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: Calling; DN 108
    19:45:02.667|.\CallTarget.cpp(412)|Trace5|CallManager|CT_Lines::Invite:Rule (Cellulare3409709606): Placing call to line 10001@L:2@C:3b to reach 3287529064
    19:45:03.077|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipResp: 100 tid=36093b291e64b35a cseq=INVITE contact=10001@192.168.10.242:5060 / 1 from(wire)
    19:45:03.188|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipResp: 180 tid=36093b291e64b35a cseq=INVITE contact=10001@192.168.10.242:5060 / 1 from(wire)
    19:45:03.188|Dialog.cxx(547)|Trace5|Resip|>>:Dialog::dispatch, ignoring stray response: SipResp: 180 tid=36093b291e64b35a cseq=INVITE contact=10001@192.168.10.242:5060 / 1 from(wire)
    19:45:03.188|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAC_Start -> UAC_Early
    19:45:03.188|.\ISHandler.cpp(31)|Trace5|CallControl|ISHandler::eek:nNewSession:Answered: sis=7159;oat=None;rl=SIP/2.0 180 Ringing
    19:45:03.188|.\CallStrategies.cpp(561)|Trace5|CallManager|StratInOut::eek:nAnswered:Call from Ext.108 is answered on Ln:10001@Altesys
    19:45:03.188|.\CallTarget.cpp(421)|Trace5|CallManager|CT_Lines::answered:Call is accepted on 10001@L:2@C:3b
    19:45:03.188|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: Ringing; DN 10001
    19:45:03.188|ClientInviteSession.cxx(315)|Trace5|Resip|>>:UAC_Early: startStaleCallTimer
    19:45:03.188|.\ISHandler.cpp(57)|Trace5|CallControl|ISHandler::eek:nProvisional:provisional: cis=7159;rl=SIP/2.0 180 Ringing
    19:45:03.188|.\CallConf.cpp(152)|Log2|CallControl|CallConf::eek:nProvisional:Call(C:3B): got response from 3287529064
    19:45:03.188|.\CallStrategies.cpp(620)|Trace5|CallManager|StratInOut::eek:nProvisional:InOut: got provisional SIP/2.0 180 Ringing from 10001@L:2@C:3b
    19:45:03.188|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: Calling; DN 108
    19:45:03.188|ServerInviteSession.cxx(91)|Trace5|Resip|>>:UAS_EarlyOffer: provisional(180)
    19:45:03.188|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_EarlyOffer -> UAS_EarlyOffer
    19:45:03.188|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend:InviteSession(7156) sends SIP/2.0 180 Ringing
    19:45:14.784|ServerAuthManager.cxx(50)|Trace5|Resip|>>:ServerAuth rejected request SipReq: REGISTER sip.baitech.net tid=622172 cseq=REGISTER contact=103@192.168.10.120:5070 / 64 from(wire)
    19:45:27.162|TuSelector.cxx(70)|Trace5|Resip|>>:Stats message
    19:45:48.724|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipReq: CANCEL 93287529064@192.168.10.76 tid=d6b4c54554c41c45 cseq=CANCEL / 44434 from(wire)
    19:45:48.724|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend:InviteSession(7156) sends SIP/2.0 200 OK
    19:45:48.724|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend:InviteSession(7156) sends SIP/2.0 487 Request Terminated
    19:45:48.724|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAS_EarlyOffer -> InviteSession::Terminated
    19:45:48.724|.\ISHandler.cpp(100)|Trace5|CallControl|ISHandler::eek:nTerminated:Terminated: is=7156;reason=PeerEnded;rl=CANCEL sip:93287529064@192.168.10.76 SIP/2.0
    19:45:48.724|.\CallStrategies.cpp(690)|Trace5|CallManager|StratInOut::eek:nHangUp:InOut: got Hang-Up from 108@L:1@C:3b
    19:45:48.724|.\CallStrategies.cpp(721)|Log2|CallManager|StratInOut::eek:nHangUp:Call(C:3B): Call from Ext.108 to 3287529064 has been terminated
    19:45:48.724|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: OnHook; DN 108
    19:45:48.724|.\CallConf.cpp(413)|Trace5|CallControl|CallConf::~CallConf:Destroying call C:3B
    19:45:48.734|.\CallStrategies.cpp(850)|Trace5|CallManager|StratInOut::~StratInOut:InOut: strategy is terminated
    19:45:48.734|.\CallEvents.cpp(78)|Trace5||FireStatusEvent:Fire event: OnHook; DN 10001
    19:45:48.734|ClientInviteSession.cxx(174)|Trace5|Resip|>>:UAC_Early: end
    19:45:48.734|InviteSession.cxx(2360)|Trace5|Resip|>>:"3409709606"<sip:altesys@192.168.10.242>;tag=047bd354 Sending BYE
    19:45:48.744|.\ISHandler.cpp(140)|Trace5|CallControl|ISHandler::eek:nReadyToSend:InviteSession(7159) sends BYE sip:10001@192.168.10.242:5060 SIP/2.0
    19:45:48.744|InviteSession.cxx(2046)|Trace5|Resip|>>:Transition UAC_Early -> InviteSession::Terminated
    19:45:48.744|.\ISHandler.cpp(101)|Trace5|CallControl|ISHandler::eek:nTerminated:Terminated: is=7159;reason=Ended
    19:45:48.744|.\Call.cpp(1344)|Trace5|CallControl|CallLegImpl::~CallLegImpl:Leg 10001@L:2@C:3b is destroyed
    19:45:48.744|.\Call.cpp(1344)|Trace5|CallControl|CallLegImpl::~CallLegImpl:Leg 108@L:1@C:3b is destroyed
    19:45:48.964|DialogUsageManager.cxx(1190)|Trace5|Resip|>>:Got: SipResp: 200 tid=721d962ef05df163 cseq=BYE / 2 from(wire)
    Stefano
