GSM Gateway on 3CX
Discussion in '3CX Phone System - General' started by inovakom, Aug 14, 2008.
  1. inovakom
    Aug 14, 2008
    I have successfuly configured the 3CX PBX and tested it. For now I did not have any problems. Now I would like to connect the GSM Gateway (2N VoiceBlue Lite) to 3CX. I have created the VoIP line for GSM Gateway, I have entered the IP of Gateway in Host name. I have established the outgoing call to mobile phone thru GSM Gateway successfuly. I have tried to establishe incoming call thru GSM Gateway and I can not establishe incoming call. The Gateway has DISA, so the user can pick wanted extension. When I enter extension on 3CX nothing happens - the call does not proceed to extesnion of 3CX. I have tried to forward all calls to extesnion 3CX. On mobile phone I have ring tne but the extesnion does not ring. In smoe cases call does not ring instead it is disconnected and I gate some information on server 3CX. In all other cases there is no information.
    These is the infomration from server
    08:08:49.578 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 75.101.138.128:3478 over Transport 191.254.1.35:5060
    08:04:45.296 AuthMgr::eek:nAuthFailure [CM102001]: Authentication failed for SipReq: INVITE 100@191.254.1.35:5060 tid=-216013290 cseq=INVITE contact=041273709@191.254.1.78:5060 / 20 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    08:04:45.000 evt::CheckAuth::not_handled [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:100@191.254.1.35:5060 SIP/2.0
    Via: SIP/2.0/UDP 191.254.1.78:5060;branch=z9hG4bK-216013290
    Max-Forwards: 70
    Contact: [sip:041273709@191.254.1.78:5060]
    To: [sip:100@191.254.1.35:5060]
    From: [sip:041273709@191.254.1.78:5060];tag=0050C281F179-125013918
    Call-ID: 0050C281F179-27017166@191.254.1.78
    CSeq: 20 INVITE
    Allow: INVITE, BYE, ACK, CANCEL, OPTIONS, REFER, NOTIFY
    Proxy-Authorization: Digest username="10000",realm="3CXPhoneSystem",uri="sip:191.254.1 .35",response="7e04e61a290b550d9af344310f0d08fa",nonce="12863167484:21e6d6bb4cfc9b00b6bb5bc9331d6175",algorithm=MD5
    User-Agent: 2N VoiceBlue V-02.07.34b01
    Content-Length: 0
    08:04:45.000 evt::CheckAuth::not_handled [CM302002]: Authentication failed due to unidentified source of: SipReq: INVITE 100@191.254.1.35:5060 tid=-216013290 cseq=INVITE contact=041273709@191.254.1.78:5060 / 20 from(wire)
    08:04:44.562 evt::CheckIfAuthIsRequired::not_handled [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    Via: SIP/2.0/UDP 191.254.1.78:5060;branch=z9hG4bK-22001065
    Max-Forwards: 70
    CSeq: 18 INVITE
    Content-Length: 0
    08:04:44.562 evt::CheckIfAuthIsRequired::not_handled [CM302001]: Authorization system can not identify source of: SipReq: INVITE 100@191.254.1.35:5060 tid=-22001065 cseq=INVITE contact=041273709@191.254.1.78:5060 / 18 from(wire)
    Does anybody have any idea what should be done to establishe incoming calls. And what could be the reason for these problem.
  2. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    http://www.3cx.com/support/source-id-errors.html
  3. inovakom
    Aug 14, 2008
    I'm afraid that these solution does not help. The incoming call is still dissconected and mentioned errors appears on server status. But the problem is that these happens only in case that I redirect the incoming call directly to extension 100 on 3CX. If there is possibility to chose the extension on GSM Gateway nothing happens on 3CX (no extesnion rings). There is also no information on server status window. I have checked the logs from GSM Gateway and GSM Gateway forwards the DTMF entry forward. Does anybody have any experiance in GSM Gateways on 3CX.
  4. igor.snezhko
    Jan 7, 2008
    668
    7
    I use Portech and it works prefect.
  5. bemas
    Aug 18, 2010
    5
    Hello All,
    I use the same set of system as described above, can someone comfirm if VoiceBlue Lite can worked with 3cx system.
