GSM Gateway
Discussion in 'Windows' started by aspiq, Jun 30, 2011.
  1. aspiq
    Jun 14, 2010
    9
    Can any body suggest me a GSM Gateway with a minimum of 20 GSM Lines from any manufacturer which can be used as a PSTN gateway with 3CX
    I have seen some product from Hypermedia which are highly scalable and have 20,24 channels etc
    Regards
    11,105
    329
    That's a lot of lines. Most units that have come up before only support a couple of lines (each line requires it's own SIM of course). You may have to go with multiple units.
    Although...you never know.
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    There are several devices like that (bluetel, its, etc.), they either support an ISDN PRI connections (upto 120 channels) and/or SIP trunks as interface to the PBX. The problem is the price of the device - a 32-channel gateway used to be over € 15,000.-
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    PORTech might offer a solution?
    http://www.portech.com.tw/p3-product1.asp?Cid=8
  5. rautenberg
    Aug 11, 2011
    I got a bunch of gsmgateways for sale.
    1x 2n Bluestar 10 gsm PRI / New price: 16 000 EUR / My price: 2 000 EUR (Never used, new in box)
    1x 2n Voiceblue 4 gsm VOIP / New price: 1 800 EUR / My price: 500 EUR (Used for 1 year)
    6x Portech MV-372 2 gsm VOIP / New price: 300 EUR / My price: 150 EUR (Used for 1 year)
    All have been running on 3cx, 20 users (the 3cx licens is also for sale) exept the 10 gsm gateway above.
    Get back if someone is intrested.
