GSM Gateway
foulad
Good day,
what i the best GSM Gateway working with 3CX , one i can find in amazon.com ?
im planning to connect 3 GSM lines to my 3CX
The Portech MV-374 is a 4 channels VoIP GSM/CDMA/UMTS Gateway and is supported by 3CX.
http://www.portech.com.tw/p3-product1_1.asp?Pid=19
http://www.3cx.com/blog/voip-howto/portech-mv-374-gsm-gateway/
Also you can take a look for 2N and Topex (i have few of them connected to 3cx, working good). Dinstar is also working but terrible voice quality
Try Dinstar (http://dinstar.com) -- easy to configure (3CX configuration guide available), working fine and price effective.
I have lots of Dinstars installed, so generally disagree with Mixig (above).
Re: GSM Gateway and Caller ID
Hi there.
Newbie question here.
Considering getting a 2 or 4 sim GSM Gateway (probably Portech 372/374). This will only be for outgoing calls.
Will the receiver of calls via the GSM Gateway get the Caller ID of the sim or can a Caller ID be setup on the gateway or 3CX server?
Thanks.
As with any GSM call, the received caller ID will be that assigned to the SIM.
Thanks for the update leejor.
I assumed this was the situation.
Hi Guys.
I am new to the 3cx system. What gsm gateways can i use for the 3cx system for inbound and outbound calls. i was looking at the beronet berofix but it has only 2 gsm SIMs. Can u plz guide me in getting one that accomodates 4gsm SIMs and can be easily configured with the 3cx system.
Portech MV-374
@Bellick
Please take note of the 1st, 2nd and 3rd reply of this thread. ;)
Thanks guys. can you guys help me with the configuration guide for the PORTech MV-374 - 4 channel GSM/VoIP Gateway for the 3cx phone system 12?
Getting Started - Admin
Hammad.k
Get 3CX - Absolutely Free!
3CX
