GSM GATEWAY
Discussion in '3CX Phone System - General' started by mon_email, Jan 25, 2008.
  1. mon_email
    Jan 23, 2008
    know somebody about some gsm gateway, working with 3CX, for inside and outside calling ?
    Or soft. client for mobile phone doing the some?
    peter
  2. alicic
    alicic New Member
    Oct 3, 2007
    119
    I have read on this forum that there are some GSM Gateways thta do work with 3cx. Please search the forum about GSM Gateway
  3. silentfun
    silentfun Member
    Dec 11, 2006
    364
    not easy to search at the moment :)
    so you have to search if the seach option is avalible again.
    but you can use standart analog gateways like grandstream 488 and behind this you put a analog to gsm gateways - if nothing else helps.
    but best wait for search
    Andy
  4. silentfun
    silentfun Member
    Dec 11, 2006
    364
