GSM Gateway
Discussion in '3CX Phone System - General' started by macuartero, Jun 16, 2008.
  1. macuartero
    Jun 16, 2008
    I'm looking for a GSM gateway for use with 3cx. I've found several models of them but I'm interested in PORTECH MV-372, cause it supports 2 GSM lines.
    I wonder if is it this device supported by 3CX software?
    Thanks in advance.
  2. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    you can find the info in:
    http://sites.google.com/a/3cx.com/3cx-wiki/Home/community-supported
    regards
