GSM via PSTN Gateway
Discussion in '3CX Phone System - General' started by bigharj, Feb 26, 2011.
  1. bigharj
    Feb 26, 2011
    I am new to 3CX and am evaluating my requirements.
    I have a Telecom FM Dual SIM GSM Gatewaway, it is an old version designed to be used with analogue PBX's, it is used on a Norstar PBX at the moment.
    Can I use an inexpensive VOIP PSTN Gateway as a bridge between the VOIP PBX and the Telecom FM Unit? The Telecom FM unit has 2 standard BT inputs, could I connect these to the RJ11 inputs of the PSTN Gateway and obviously the PSTN gateway to the LAN? I plan to use this for outgoing calls only.
    Is the configuration of the VOIP PSTN Gateway on 3CX as easy one?
    Kind Regards
    Harj
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    In theory yes
    I would use one of the supported PSTN gateways such as the Grandstreams to connect it to you Telecom unit. They are easy to configure from the console if you use the provisioning templates from the console for the supported gateway
  3. leejor
    10,754
    286
    If you were planning on using just a single line then something like the Linksys SPA3102 would work for you(FXO port), unless you had plans to add more PSTN trunks in the future. The only thing I would be concerned about is what sort of disconnect signal (if any) is sent back to the analogue device. If there is a momentary disconnect (CPC) then great, if a mobile that was called, hangs up, then it would disconnect the trunk at the 3CX end if the call were placed on hold or "lost" in the system. Otherwise there are a number of disconnect settings that could be tweaked so that a trunk is not held up unintentionally.
