GUI selects next extension number in range
Discussion in 'Ideas' started by TRILAN_SteveG, Oct 31, 2017.
GUI selects next extension number in range 4.6 5 8votes
4.6/5, 8 votes
  1. TRILAN_SteveG
    Oct 29, 2015
    9
    10
    Hi there,
    When adding new extensions to large systems the 3CX will now default to exteniosn number 0000 and you have to manually go and find the next one availble in the range you want. We have several Ranges on a system and would like the ability to select the first extension in a range e.g. 3000 and then when we go to add a new extension it would automatically sleect the next available extension number in the range of 3000-3999.
    Thanks in advance.
  2. dualcore
    Nov 23, 2017
    This should be default behaviour on extensions, and should be fairly easy to implement.
