.gw templates files do not appear in Templates Drop-Down list
Discussion in '3CX Phone System - General' started by azizgstest, Oct 12, 2016.
  1. azizgstest
    Oct 12, 2016
    I'm using 3CX V15 and uploaded some templates to provision my phones and gateways, I was able to provision the phones correctly however the gateways templates do not appear in the drop-down list.
    When I click on add button, It specifies the file extension as ph.xml , does this means that gw.xml is not supported anymore ?
    Thanks in advance.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,153
    172
    Send us a gateway template so we see it..
  3. azizgstest
    Oct 12, 2016
    I'm unable to find the default templates for the gateways. I'm attaching a screenshots and two templates.
    am I doing something wrong ?
