GW4104 - Destination not Found
Discussion in '3CX Phone System - General' started by Alliedbs, Jul 12, 2009.
  1. Alliedbs
    May 29, 2009
    19
    i have setup gw4104 gateway and a 3cx voip client. I try to dial out but say destination not found. The out bound rule i have set as below
    Call to number strating with ( Prefix ) 9
    Call from Extension 100-999
    calls to number with a length of 8
    Strip digits 1
    prepend 9
    I call using 9 follow by nos but keep saying destination not found.
    Kindly pls advise where did i do wrong.
    Thanks......
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    I think the default is 99
    and you have to specify the line (1 to 4)
    you have to set prepend to 991 (for pstn line1)
  3. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    There are too many options in the outbound rule, try removing a few and see what the results are.
    I would start by removing the number length of 8 rule as if your local numbers are 8 digits long and you prepend a 9 in front of the number you will never make a call because the number sent will have 9 digits.
  4. voipbaennjer
    Jul 10, 2009
    44
    The GXW4104 works in round robin mode (it seizes one line after the other). But each induvidual line can be accessed by dialing 99 plus line number (1-4).
    So prepend 991 for line 1 in your outbound rule to access line 1 (992 for line 2 and so on).
    If you want to make outgoing calls by dialing 9 you also have to strip 1 digit in your outbound rule.
    Leave the extension field blank since 100-999 specifies all extensions anyway.
