GWX4104 Template
Discussion in '3CX Phone System - General' started by cobaltit, May 27, 2013.
  1. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,580
    237
    Looks like it needs to be updated to add the %%PROVSUBDIR%% variable to it. I'm assuming the other GW templates may need it as well.
