gxp 2000 cannot accept more than a call (Solved)
Discussion in '3CX Phone System - General' started by patroclo, Feb 4, 2011.
  1. patroclo
    Jan 22, 2011
    9
    3cx pbx free version
    7 phones (grandestream gxp 2000, last firmware) in one ring group
    this is the issue:
    once a phone is engaged, the phone can only accept other incoming calls that are sent to it composing the proper extension
    Engaged phones cannot get incaming calls when they are sent via a ring group (external calls)
    I have already checked "I want to be able to accept more than 1 call at the same time uses Phone status", but it doesnt work.
    thx
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Re: gxp 2000 cannot accept more than a call
    Hi could you please reproduce this again and then post a copy of the 3CX Logs
  3. patroclo
    Jan 22, 2011
    9
    hi davidbenwell
    Thank you for your interest
    but I found the solution
    I set ALLOWUSEBUSYOPTFORGROUP variable to 1 in Phone System , Settings, Advanced , Custom Parameters
    And it works. :)
