GXP-2140 with Sidecar
Discussion in '3CX Phone System - General' started by brianoakes, Jun 15, 2015.
  1. brianoakes
    May 12, 2012
    95
    Howdy!
    I am testing a grandstream 2140 with a sidecar. I have added some BLF extensions to the side car. I don't see the display name just the extension number.
    Has anyone seen this problem before?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    Check the GS Template. Ensure the name and user id is programmed as follows for each BLF. (This is EXT MPK 2)
    # Name
    P23007 = %%blffirstname2%% %%blflastname2%%
    # UserID
    P23008 = %%blf2%%
  3. brianoakes
    May 12, 2012
    95
    That was it!
    Thanks, appreciate it!
