GXP Firmware upgrade
Discussion in '3CX Phone System - General' started by vitor, Jan 7, 2019.
  1. vitor
    Jan 3, 2019
    10
    hello
    first time doing phone provisioning... need some help
    i have done the following procedure... (https://www.3cx.com/sip-phones/manually-provision-supported-grandstream-gxp/)
    and have also downloaded the firmware file from 3cx website and added to the folder (C:\ProgramData\3CX\Instance1\Data\Http\Interface\provisioning\marjmzp3g7k0\firmware_new)
    and rebooted the phone (after setup) but the phone still keep with the same firmware version....
    is there something wrong?
    thanks
    Vitor
  2. jakem
    Apr 3, 2018
    5
    I have found the firmware_new vs firmware folders to be part of the issue. Documentation seems to vary as to where the file should be. If one doesn't work, try the other.
    I have also found that 3CX will overwrite that file. Unfortunate that 3CX doesn't better support the Grandstream firmware. The version that is supported currently was pulled by Grandstream due to a major bug with calls not picking up. 3CX is 3 versions behind currently.
  3. vitor
    Jan 3, 2019
    10
    Hi @jakem
    I did upload the file on both folders.. but didnt work
    is there any manual way to upgrade the GXP firmware?
    thanks
  4. jakem
    Apr 3, 2018
    5
    The server will tend to "upgrade" the phones to a lower version if you do it manually. I would recommend checking the little things. I beat my head against the wall for an hour once before I realized I had the wrong GXP firmware file, I had the GXP2130 instead of GXP2160. Make sure the file ends in .bin not .zip, etc. I have done this a number of times, and the method you used should work, so check the little things.
  5. vitor
    Jan 3, 2019
    10
    thanks.. will try... im downloading directly from 3cx webiste... =(
  6. jakem
    Apr 3, 2018
    5
    Download from grand stream's website. http://www.grandstream.com/support/firmware
    Like I said, the current 3CX firmware is junk. It sounds like you may not even have the phones in the 3CX server yet though, the server will automatically download any 3CX firmware if it is available, the problem right now is that the version hosted by 3CX is crap.
  7. vitor
    Jan 3, 2019
    10
    yes... i did the download form this URL.
    i have an issue, when I do any phone configuration change I receive a incoming call... have you faced it?
    thanks
  8. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    564
    Hello @vitor
    From your description i would assume that the phones are already provisioned and working. If so then the 3CX supported firmware should be available for download in the Updates tab of the PBX (if you are using a supported model).
    Once you download it you should be able to update the phones through the management console. To be able to provide more accurate information please let us know how the phones are provisioned Local, Stun or SBC), what GXP models are you using and the current firmware the phones are running.
    Also manually adding a firmware in the firmware folder won't work as the PBX reads the available firmware version from a file that gets updated once a new firmware is downloaded.
  9. vitor
    Jan 3, 2019
    10
    hello @support
    im using GXP 1610 - Im using local provision process.
    the phone firmware version is
    Product Model
    GXP1610
    Software Version
    Boot
    1.0.4.5
    Core
    1.0.4.55
    Base
    1.0.4.66
    Prog
    1.0.4.82
    Locale
    1.0.4.67
    Recovery
    1.0.4.53
    Its possilble to FORCE software upgrade?
    How can I make sure the provision is working?
    thanks
  10. HRMNY
    Feb 8, 2018
    36
    11
    /var/lib/3cxpbx/Instance1/Data/Http/Interface/provisioning/XXXXXXXXXX/firmware_new/grandstream
    Overwrite the .bin with the newer version.
    Edit firmwares.json,
    Changed the following fields to match the new firmware number.
    "Version":
    "ServerVersion":
    "LocalVersion":
    Reboot the server, and update the phones.
  11. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    When will 3cx release a firmware fix for the GS Phones?
  12. vitor
    Jan 3, 2019
    10
    @craig
    the version 1.0.4.125 still have this "incoming ring" error?
    thanks
  13. vitor
    Jan 3, 2019
    10
    still the same... dont know if im missing something...
  14. alan nogueira
    Jan 9, 2019
    9
    Hello Victor,
    There are many ways to do it, explained at 3cx tutorials.
    The easiest one is loggin into your 3cx panel -> Phones -> select your Grandstream in the list (you have to provision it first) -> then click "Firmware" button. It will install automatically.
    Here´s the link: https://www.3cx.com/sip-phones/manually-provision-supported-grandstream-gxp/
    Unfortunately, it didn´t work for me.
    The way i found was changing the update server in the phones gui:
    1) open web browser and type your Grandstream´s IP address
    2) the default user / password is admin / admin (if you have provisioned it in 3cx, the user is admin and the password you can see at the 3cx control panel -> extensions - click in the "password" button and use the one listed in the "Phone pwd" collumm - ITS DIFFERENT FROM YOUR EXTENSION PASSWORD).
    3) Click "Manteinence" -> Upgrade and provisioning
    4) At "Firmware" change "Firmware Upgrade via" to "HTTP" and Firmware server Path to "firmware.grandstream.com" and click "Save and apply".
    5) Your phone will reboot and install the firmware. It will take several minutes...
    6) After installing, factory reset your phone https://www.3cx.com/sip-phones/factory-reset-grandstream-gxp/
    7) Then you should provision your grandstream again (the full tutorial for this model: https://www.3cx.com/sip-phones/grandstream-gxp16-series/
    Have a good luck, if you have any doubts please ask
    Alan
