GXP2000 Restarting 1.1.5.15 Restarting BLF
Discussion in '3CX Phone System - General' started by AldoLinares, Dec 7, 2007.
  1. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    After i enabled BLF on the Grandstream GXP2000 the phone it's restarting itself, it can happen without any reason but more of the times happen when i get a call or when one of the BLF Leds change.
    Anybody have this problem too?
  2. silentfun
    silentfun Member
    Dec 11, 2006
    364
    no wonder 1.1.5.15 is shit too mutch trouble
    hope Grandstream fix all that trouble
    - BLF is like a Oracles Guess
    - is some conditions when u want to change something via web interface the phone freeze
    - it seems that it forget to refresh the registering at the PBX server. all other phones show register expired and then reregister but not the GXP with new firmware - when i try a call next mornig i can not without reboot
    - if you use other then english language u have trouble with ÄÖÜß and so on.
    - XML Applications for softbuttons don´t run
    - idle/custom screen have no status bar and not all variables u need
    - and the display texts are much too big. ok 1.1.4.17 was a bit small but hey this is too big now.
    - sometimes it have bad timeouts so if you dial fast 12345 it only accept 12 and eat the rest and u have to type again 345 and the push send or wait 4 seconds
    so i have decided to go back to 1.1.4.17 because it is stable but have no xml Appl. it run ok with V3.
    so beware of GXP-2020 1.1.5.15
    Andy
  3. scottyork
    Jun 1, 2007
    64
    Same problem with same firmware on 2000. :(
    Will try rolling it back.
  4. scottyork
    Jun 1, 2007
    64
    1.1.4.18 work OK
    Rolling back to 1.1.4.18 seems to fix the problem.
    But now I can't turn off the backlight for missed calls.
  5. AldoLinares
    Nov 12, 2007
    135
    Where did you get the older version?
  6. scottyork
    Jun 1, 2007
    64
    I had it from a previous upgrade. PM me if you want it sent.
    I think you may be able to find it out on the web. I recall a site holding archives but can't find it at the moment.
