GXP2140/GXP2160 Templates
Discussion in '3CX Phone System - General' started by brianoakes, Mar 27, 2014.
  1. brianoakes
    May 12, 2012
    92
    Does anyone have any templates they wish to share?
    We are considering moving from Polycoms to Grandstreams. is this a good move? If, not if there another phone we should look at?
    The main reason is the users find the Polycoms too complex to use. So we are looking at something very simple and easy to use. Most of the users are familiar with OLD PBX systems.
    Thanks!
  2. ThomasN
    May 30, 2012
    12
    Grandstream templates and (beta) firmware is ready for download on the resellerconnect portal from Grandstream. We are having 30 GXP2160's deployed at a client at the moment and so far no problems with it.
  3. brianoakes
    May 12, 2012
    92
    Thanks. I'm not a reseller so I guess I can't get them. I did my own 3CX install, and just buy phones on the web for our company. I have some GXP2140/GXP2160 that I want to test and give to a few users to see if that is what we want to use.
    if anyone can share, that would be great. Appreciate it!
  4. ThomasN
    May 30, 2012
    12
    http://resellerconnect.grandstream.com/files/marketing/voip/templates/3CX_Templates.zip
  5. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    I wouldnt hesitate to mke that change at all the Grandstreams are excellent handsets and as stated you can find config templates as well as firmware on their reseller connect page. We've maybe close to 100 2160's in use and I've yet to experience any troubles to this point, if you do tech support can help though its not the best support out there.
  6. Brian Cross
    Brian Cross New Member
    Jul 26, 2017
    109
    27
    Any chance on getting this template from someone?
  7. Brian Cross
    Jul 26, 2017
    109
    27
    I got the templates from grandstream support. No luck in provisioning a phone with them though. Using version 15.5.
