this is what I get when I try to make a call, at the bottom of the file is where i reset the 4004
04-Aug-2015 13:58:29.868 Leg L:1834.1[Unknown:] is terminated: Cause: BYE from PBX
04-Aug-2015 13:58:29.862 [CM502001]: Source info: From: "130"<sip:
[email protected];user=phone>;tag=1762410600; To: <sip:
04-Aug-2015 13:58:29.862 [CM503013]: Call(C:1834): Incoming call rejected, caller is unknown; msg=Ivite-IN Recv Req INVITE from 10.10.10.106:5062 tid=1403375659
[email protected]:
INVITE sip:
[email protected];user=phone SIP/2.0
Via: SIP/2.0/UDP 10.10.10.106:5062;branch=z9hG4bK1403375659;rport=5062
Max-Forwards: 70
Route: <sip:10.10.10.140:5060;lr>
Contact: "130"<sip:
[email protected]:5062;user=phone>
To: <sip:
Call-ID:
[email protected]
CSeq: 11 INVITE
Accept: application/sdp, application/dtmf-relay
Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, SUBSCRIBE, NOTIFY, INFO, REFER, UPDATE
Content-Type: application/sdp
Proxy-Authorization: Digest username="130",realm="3CXPhoneSystem",nonce="414d535c0bd19c5535:14a58eb7fa66fbbef8eb4832e6adc2ce",uri="sip:
[email protected];user=phone",response="a575d66532d3cac6414ff5a1401a76e1",algorithm=MD5
Supported: replaces, path, timer, eventlist
User-Agent: Grandstream GXW-4004 V1.5A 1.0.12.4 chip V2.2
Privacy: none
P-Preferred-Identity: "130" <sip:
Content-Length: 451
v=0
o=130 8002 8000 IN IP4 10.10.10.106
s=SIP Call
c=IN IP4 10.10.10.106
t=0 0
m=audio 5008 RTP/AVP 0 8 4 18 2 97 102 100 101
a=sendrecv
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:8 PCMA/8000
a=rtpmap:4 G723/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:2 G726-32/8000
a=rtpmap:97 iLBC/8000
a=fmtp:97 mode=20
a=rtpmap:102 G729E/8000
a=rtpmap:100 AAL2-G726-16/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16,32-36,54
04-Aug-2015 13:57:29.589 [CM504001]: Endpoint Extn:122: new contact is registered. Contact(s): [sip:
[email protected]:5066 / 122]
04-Aug-2015 13:57:29.405 Got REGISTER for foreign registrar: registrar host <sip
10.10.10.140.5060:5060> is not mine!
04-Aug-2015 13:57:28.288 [CM504001]: Endpoint Extn:121: new contact is registered. Contact(s): [sip:
[email protected]:5064 / 121]
04-Aug-2015 13:57:27.926 Got REGISTER for foreign registrar: registrar host <sip
04-Aug-2015 13:57:26.822 [CM504008]: Fax Service: Fax.130 registered as sip:
[email protected] with contact sip:
04-Aug-2015 13:57:26.576 Got REGISTER for foreign registrar: registrar host <sip
04-Aug-2015 13:57:25.451 [CM504001]: Endpoint Extn:106: new contact is registered. Contact(s): [sip:
[email protected]:5060 / 106]
04-Aug-2015 13:57:25.086 Got REGISTER for foreign registrar: registrar host <sip
