GXW4104 Intermittent CID issue
Discussion in '3CX Phone System - General' started by FGCUHank, Mar 9, 2011.
  1. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    After a few days my GXW4104 starts sending trash for the CID to 3cx. I see it in the 3cx logs as well. See example from a voicemail e-mail below.
    If I login to the GXW and reboot it, the issue goes away.
    Anyone run into this before?
    Thanks for any input.
    From Caller ID 23NMM&&&&&
    Date 3/8/2011 4:39:41 PM
    Duration 00:00:49
    File vmail_23NMM&&&&&_10_20110308213941
    Product Model: GXW4104
    Software Version: Program--1.3.4.10 Loader--1.1.3.4 Boot--1.1.3.2
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Please post the 3cx logs, but its best you go to grandstream and ask them about the issue. Furthemore the tested firmware for this device is 1.3.1.6 i suggest you stick with it.
  3. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    Thanks for the reply,
    Here is the section from the logs on that call. I've seen this a few times since installing the GXW. The issue goes away with reboot.
    I'll try my luck with GS but have not had much with them in the past. I may try to downgrade the firmware (if possible) or go back to my SPA3102.
    11/03/08 16:38:25.253|100031| Trc|75|0008|: Call update(Insert): cid=2, dn=10004, internal=(none), external=23NMM&&&&&, ac_stat=Dialing
    11/03/08 16:38:25.472|100031| Trc|75|0008|: Call update(Insert): cid=2, dn=Ext.14 Hank Grimmick, internal=10004, external=23NMM&&&&&, ac_stat=Ringing
    11/03/08 16:38:25.519|100031| Trc|75|0008|: Call update(Insert): cid=2, dn=Ext.10 Kitchen, internal=10004, external=23NMM&&&&&, ac_stat=Ringing
    11/03/08 16:38:45.441|100031| Trc|75|0008|: Call update(Update): cid=2, dn=10004, internal=14, external=23NMM&&&&&, ac_stat=Dialing
    11/03/08 16:38:45.456|100031| Trc|75|0008|: Call update(Delete): cid=2, dn=Ext.14 Hank Grimmick, internal=10, external=23NMM&&&&&, ac_stat=Ringing
    11/03/08 16:38:45.519|100031| Trc|75|0008|: Call update(Delete): cid=2, dn=Ext.10 Kitchen, internal=10004, external=23NMM&&&&&, ac_stat=Ringing
    11/03/08 16:38:45.644|100031| Trc|75|0008|: Call update(Insert): cid=2, dn=99, internal=10004, external=23NMM&&&&&, ac_stat=Ringing
    11/03/08 16:38:45.675|100031| Trc|75|0008|: Call update(Update): cid=2, dn=10004, internal=99, external=23NMM&&&&&, ac_stat=Connected
    11/03/08 16:38:45.691|100031| Trc|75|0008|: Call update(Update): cid=2, dn=99, internal=10004, external=23NMM&&&&&, ac_stat=Connected
    11/03/08 16:38:47.847|100036| Trc|75|0008|: Agent's 19 phone is registered
    11/03/08 16:38:50.331|100039|Stat|75|0003|: Statistics:
    QM Total:
    calls_waiting_now: 0
    calls_polling_now: 0
    calls_servicing_now: 0
    calls_seen_in_wait: 0
    calls_seen_in_poll: 0
    calls_serviced: 0
    calls_dropped_before_poll: 0
    calls_dropped_before_delivery: 0
    calls_whose_wait_timer_expired: 0
    callbacks_requested: 0
    11/03/08 16:39:20.331|100039|Stat|75|0003|: Statistics:
    QM Total:
    calls_serviced: 0
    11/03/08 16:39:23.097|100036| Trc|75|0008|: Agent's 16 phone is registered
    11/03/08 16:39:41.097|100031| Trc|75|0008|: Call update(Delete): cid=2, dn=10004, internal=99, external=23NMM&&&&&, ac_stat=Connected
    11/03/08 16:39:41.112|100031| Trc|75|0008|: Call update(Delete): cid=2, dn=99, internal=(none), external=23NMM&&&&&, ac_stat=Connected
    11/03/08 16:39:50.378|100039|Stat|75|0003|: Statistics:
    QM Total:
    calls_serviced: 0
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Hi FGCUHank,
    Management console provides "Server Activity Log" page. It shows information which is enough to initiate investigation.
    Why don't you use it?
  5. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    Hi Stephan,
    The event happened yesterday and scrolled off the window before I could grab it. I searched for the caller ID string in the logs and log backup directories and found it in the following files.
    3CXAssistantServer.exe.log
    CallHistoryService.log
    CallHistory20110306.log
    3CXDialier.040828.log
    3CXQueueManager.040826.log
    I can post the sections from each or is there one you would prefer?
    Thanks in advance.
