GXw4104 not answering
Discussion in '3CX Phone System - General' started by bigsiqc, Jul 16, 2009.
  1. bigsiqc
    Nov 21, 2007
    23
    I have followed the instructions to get a gxw4104 installed. I can dial out fine, but incoming calls are answered by a dailing tone then disconnect.
    There is nothing recorded on the server log even though it is set to verbose. It just doesnt seem to be communicating with 3cx at all.
    The gxw 4101 is using Program-- 1.2.1.5 Loader-- 1.1.3.4 Boot-- 1.1.3.2
    Any ideas?
    thanks
    Simon
  2. ec268
    Apr 18, 2009
    22
    Do you see the 4104 registered in 3CX well?
    ie all 4 spots green on
  3. bigsiqc
    Nov 21, 2007
    23
    Yes it seems to register fine. When I make an outgoing call the light changes colour but when I dial in there is no response at all.
    Do you thik it is a faulty box?
  4. jharrell
    Jun 23, 2009
    23
    Do you have the "Unconditional Call Forward to VOIP" parameter setup properly?
  5. bigsiqc
    Nov 21, 2007
    23
    THANK YOU.
    You were right. the box wasnt holding the setting for unconditional call forwarding. A factory reset and Bobs your uncle... it works!
  6. jharrell
    Jun 23, 2009
    23
    I just know I had the same issue, I think mainly because the settings don't really make much sense, why do you have to setup a sip ID for each channel, then again setup which sip ID each channel goes to? What does the phone number setting do vs the unconditional call forward? Not documented very well.
    I am not a huge fan of the disconnect in gateway and the 3cx Trunk lines for inbound vs outbound either, makes things even more confusing.
    You map Sip ID to channels, but on outbound calls picks the highest available port to go out on regardless, so you can never tell from the 3cx console which outbound line it's really using, also 3cx seems to pick outbound trunks at random as well, double confusing.
